Import
All  1  2-11
4931.2
Basically convert from NURBS (MoI) to Mesh (obj) is possible, but the inverse way is very hard to do.
4931.3
Hi Rich, there is an utility to import obj as a wireframe reference:
http://kyticka.webzdarma.cz/3d/moi/#importobj
Marc
4931.4 In reply to 4931.3
hi all
can we use it on osx ?
Laurent
4931.5
Thanks for the info guys...
I'll try the converter...
Peace,
Rich_Art. ;-)
Hi Rich,
please check my signature for this topic. I used a triangle mesh as example. You can use the NURBS Surface option provided in Houdini if you have a quad mesh for example. If the mesh consists of tris and quads you may have to check what fits best for you.
Best regards
EDITED: 16 Feb 2012 by STEFAN
4931.7 In reply to 4931.6
Mmmhh my sig get's deleted when i edit my post....
4931.8 In reply to 4931.1
Hi Rich_Art - yeah it's because OBJ files usually contain polygon mesh geometry which is a totally different way to structure 3D objects than the NURBS geometry that MoI is focused on working with.
MoI can export to polygons in OBJ format, which it does by taking large spline surfaces and dicing them up into little facet pieces. But it is not easy to start with a whole lot of little diced up pieces and then try to form large truly smooth surfaces out of those.
See here for some previous discussion:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4421.6
4931.9
Thanks guys... I will read everything. :-)
The problem with this community is, when I click a link to another post or topic I see more interesting things and so on.. Before I know I have 20 tabs open in Firefox. :-) and I want to test all the tips etc..
Am I the only one? Glad I have some free/spare time in my daily job as an IT field support engineer to try and test all the tips.
Thanks again guys...
Peace,
Rich_Art. ;-)
4931.10 In reply to 4931.4
Hi Laurent,
> hi all
You mean the wireframe converter utility program? No - I currently only have a windows version of that helper program.
4931.11 In reply to 4931.10
hi all
Michael :
Yes that was my question.
Laurent
Show messages: All  1  2-11
