Humble script request
All  1-5  6-19
4930.6 In reply to 4930.3
Also check out the ToroidalHelix one:
http://moi3d.com/forum/display.php?webtag=MOI&msg=1519.12
That's a similar type of thing. Check out the .js files there to see the script code that is plotting points at increasing parameters of a function and then it takes all those points and builds a curve out of them.
You should be able to follow the same general pattern for your case, you need to do some stuff like figure out what parameters you want to expose in the UI and stuff like that.
4930.7 In reply to 4930.1
You can also use Flow to introduce a shear effect, that might help give you the kind of shape you want before wrapping it around a circle like Brian shows above.
To do a shear using flow, set up a base plane under your object, and then make a copy of the plane over to the side, turn on control points of the plane and shift them to make a parallelogram type shape, like this (also see attached 3DM file):
Then you can select the helix, run Transform > Deform > Flow - pick the plane that is right under the helix as the base surface, and then next pick the slanted one as the target, that will produce this kind of result:
4930.8 In reply to 4930.7
Thanks a lot. From a quick test, the Flow method with skewing works nicely!
I tried to modify the Sinus Curve script, but got an error (attached).
Best,
Morten
4930.9 In reply to 4930.8
Hi Morten,
What was the error?
Also it looks like you also need to attach the CantedCoilSpring.htm file that has the UI in it too, in order for me to be able to do a test run over here.
4930.10 In reply to 4930.8
By the way you also might be interested in this other discussion thread that shows how to use Flow to introduce compression or expansion of coils too:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4876.2
These are very cool springs. They make great electrical connectors in medical devices, and electronics.
Of the many patents, Peter J Balsells is one of the main creators.
In one patent, the springs are not just a simple helix of steel which is pushed into a groove, circular or otherwise.
During the winding, different angles are created in the steel.
Contrary to this, the thesis formula appears to be symetrical in the z axis...
For a script, I would make the assumption that the spring runs along a straight line, not a circle, and then use flow. (?)
One iteration would make one coil, of 1/w offset.
To script along a circle, I think would require another equation, which would rotate each coil around a polygon, (or circle).
The polygon would have the same number of sides as number of coils.
Or the circle would have to have the correct circumference to accomodate an integer number of coils...
Michaels method looks excellent for viewing the circular canted coil.
A script would be fairly easy, I think.
Here is a simple menu:
4930.13 In reply to 4930.12
Hi Brian, does that one match the script above? It looks like they have different names - CantedCoilSpring.js versus CantedToroidalHelix.js ...
4930.14 In reply to 4930.13
Sorry, it is the same htm.
I've dropped toroidal thoughts for now.
Wrote a canted helix script, but of course it does not work.
It sort of worked for a while, but now I've completely broken it. :-)
I always get messed up with t = 1/(number of something). And number of coils per unit length.
Got the CantedHelix script to work.
It was necessary to adjust the formulas.
(The use of w had to be modified.)
EDITED: 15 Feb 2012 by BEMFARMER
Size: 26.7 KB, Downloaded: 36 times, Dimensions: 224x295px
4930.16 In reply to 4930.15
Picture:
I suppose it could be turned into a toroid, without too many hours of work?
Size: 70.1 KB, Downloaded: 32 times, Dimensions: 185x367px
4930.17 In reply to 4930.16
Hi Brian, yeah what about using Flow to bend it around a circle like you showed earlier in this thread?
4930.18 In reply to 4930.17
Flow should work great!
I'm curious if the skewed helix is the same as a canted one...
The script does't set the length like the MoI helix command can...
4930.19 In reply to 4930.18
Yes, these are very cool springs! Making a lamp that can twist... Still very much in progress.
The script works perfectly in combination with the Flow function.
Thank you very much, both of you.
Best,
Morten
EDITED: 16 Feb 2012 by RUMLAB
Size: 81 KB, Downloaded: 113 times, Dimensions: 547x404px
Show messages: All  1-5  6-19
