Humble script request
All  1-11  12-19
Here is a simple menu:
4930.13 In reply to 4930.12
Hi Brian, does that one match the script above? It looks like they have different names - CantedCoilSpring.js versus CantedToroidalHelix.js ...
4930.14 In reply to 4930.13
Sorry, it is the same htm.
I've dropped toroidal thoughts for now.
Wrote a canted helix script, but of course it does not work.
It sort of worked for a while, but now I've completely broken it. :-)
I always get messed up with t = 1/(number of something). And number of coils per unit length.
Got the CantedHelix script to work.
It was necessary to adjust the formulas.
(The use of w had to be modified.)
EDITED: 15 Feb 2012 by BEMFARMER
Size: 26.7 KB, Downloaded: 36 times, Dimensions: 224x295px
4930.16 In reply to 4930.15
Picture:
I suppose it could be turned into a toroid, without too many hours of work?
Size: 70.1 KB, Downloaded: 32 times, Dimensions: 185x367px
4930.17 In reply to 4930.16
Hi Brian, yeah what about using Flow to bend it around a circle like you showed earlier in this thread?
4930.18 In reply to 4930.17
Flow should work great!
I'm curious if the skewed helix is the same as a canted one...
The script does't set the length like the MoI helix command can...
4930.19 In reply to 4930.18
Yes, these are very cool springs! Making a lamp that can twist... Still very much in progress.
The script works perfectly in combination with the Flow function.
Thank you very much, both of you.
Best,
Morten
EDITED: 16 Feb 2012 by RUMLAB
Size: 81 KB, Downloaded: 113 times, Dimensions: 547x404px
Show messages: All  1-11  12-19
