Fillet
All  1-6  7-11
4928.7 In reply to 4928.6
Michael fillet on the bottom piece in the recessed part as you do?
Thank's
4928.8 In reply to 4928.7
Hi Tony - just loading your file and filleting the bottom piece works fine for me over here:
Are you possibly trying to use too large of a radius value?
For a fillet on this piece you've got some quite narrow areas on it and that will limit the fillet to a radius of not larger than around 0.02 units, any larger than that and the pieces from different sides will start to collide into one another:
Fillet will have problems if you try to ask for a fillet radius that is larger than will actually fit in the available space in the model.
Sometimes it can be surprising just how much room a fillet takes up - if fillet does not work with your first radius value it is often a good idea to try some smaller and smaller values, like 1/10 of your initial value, then 1/20, 1/50, etc... just to see if that was the problem.
4928.9
Thanks michael it is strange to a PC running the other no
I can not explain this thing
4928.10 In reply to 4928.9
Hi Tony,
I'm sorry I don't understand what this part means - are you still having a problem with the fillet?
You should be able to fillet the file you posted as long as you do not use a radius of larger than 0.02 units. There is not enough space in the thin areas of your model to fit a fillet any larger than that.
4928.11 In reply to 4928.10
Ok now it works
I do not know what happened before
Thank you Michael
Show messages: All  1-6  7-11
