Array Multiple selection ?
All  1-8  9-12
4918.9 In reply to 4918.8
Yes all your methods are fine!
It's just for find something to avoid the manual part of the first displacement of the curves between them ;)
I believe that I have found a trick ;)
I project all curves on an Inclined plane ...maybe the solution...
I am on the way :)
EDITED: 12 Feb 2012 by PILOU
Ok that was easy!...but after some try :)
the concept :)
And now all the "Flow method" above can work! ;)
PS hum hum After reflexion my concept is not so good!
From View top curves result are not "Flat" ! So Flat them one by one is not a solution!
And even deform from the original!
I must rethink to that :)
EDITED: 14 Feb 2012 by PILOU
> There is maybe an Array Dir then make a tricky selection for
> erase that don't wanted in one move!
<< Sorry I'm not understanding this part... But Array Dir is about replicating one object to make multiple repeated copies of it.
I can use the Array dir for replicate all the offset curves in one inclined direction
and maybe from a view i can select with just one selection box all curves
except one curve on the first group copyed, except 2 curves in the second group copyed etc...
for obtain that
Started with epicycloidal gear. Offset. MoveSliceToPoint and loft. Sweep point.
EDITED: 13 Feb 2012 by BEMFARMER
Show messages: All  1-8  9-12
