fillet trouble again
All  1-9  10-13
4914.10 In reply to 4914.7
Hi Laurent,
""""""Can i ask you what was the way you proceed ?""""""""
For the model i posted, you can just select the entire model and run fillet .02.
Michael gave a good explanation. If you wanted to start doing "edge fillets", these will succeed too, but you have to pay attention to selecting "all the edges" that play into the surfaces in question. It can also eventually lead you into a corner where you are left with an edge that cant be calculated. Viacad is really good at doing these segmented edge fillets and completing a result.. If you want to start selecting several single edges and running various fillets in different areas, it will require more time spent. You will have left the push button fillet arena so to speak.
4914.11 In reply to 4914.10
Here's a quick video to show a failed edge selection, then one that succeeds.
Here's a screen grab of a single edge selection. Note that selecting just this edge will fail a fillet. But, look what would have to change for a fillet to go "only on that edge!" Selecting the little curve in the adjoining fillet will allow the filleter the knowledge to create a little cap there.
Also, if you start looking at it from a single edges picking fillet process, you can see how you can get backed into a corner. At this corner, you would need to practice more advanced, lower level modeling techniques to finish.
4914.12 In reply to 4914.11
Cool tricks ;)
4914.13 In reply to 4914.12
thank you all for your help.
i'll continue training.
Laurent
Show messages: All  1-9  10-13
