unexpected result with sweep
All  1-4  5-9
4907.5 In reply to 4907.2
And the difference between the auto place and non-auto place probably has to do with where the seam of the circle happens to be located.
At any rate, if you use a circle of just a tiny bit smaller radius it will likely work better.
4907.6 In reply to 4907.5
Thanks Michael
Can you please explain what you mean by "where the seam of the circle happens to be located" new to 3D modelling and not sure what you mean.
(non-auto seemed to work every time I tried has long has I place the profile on a straight edge :) )
4907.7 In reply to 4907.6
HI steve - re: "seam of the circle" - that's referring to the starting and ending point of the circle. A closed curve is formed basically the same as an open curve, just with the ending point of the curve touching the starting point of the curve.
The particular location of that start/end point will then have an influence on the similar seam edge of the closed tube that is then generated.
Just like a closed curve has the start and end on the same point, a surface that is closed in one direction like a tube or a cylinder has a "seam edge" where 2 edges of the surface come together.
4907.8 In reply to 4907.7
Michael
I just experienced something similar with sweep (see attached file). only red rail gave me straight and clear outcome.
THANKS. keep rolling.
REGARDS
4907.9 In reply to 4907.8
Hi Mario, did you possibly attach the wrong file? That file seems to be a floorplan and elevation and there are about 2000 curves in the file so I'm not sure which ones in particular you are trying to sweep.
Show messages: All  1-4  5-9
