Recent Projects
 1-4  5-24  25-44  45-64  65-79
490.45 In reply to 490.44
Col. Heres a Rising Sun Badge for the Slouch Hat if of any use to you.(The pdf Trace will open in MoI to work on)
Brian
EDITED: 30 Dec 2008 by BWTR
490.46 In reply to 490.45
Hi Everyone,
Thanks for the compliments on the model.
Michael, yes, I feel I'm just starting to get a better understanding of how to use the Tool sets.
Still a long way to go, but I'm much more confident with each model I do.
Brian, from memory I did the very top of the hat using Network curves.
I then switched on the curves Points & then tweaked them to give a more "organic" look.
I do know that it took me quite a few goes at making different shaped curves to get close to what I wanted.
Thanks for the Rising Sun, not really sure if I'll need it now, but handy just the same.
regards Colin
490.47 In reply to 490.46
Colin.
I had some great learning exercises from studying that ring. I puzzled for ages over the hat band layers and, when my mind worked, I laughed at the simplicity of doing it.
Brian
490.48 In reply to 490.47
The hat band was just a Profile I made with the "creases" in it.
I then did a Sweep, with one of the rails being a deformed curve to get that higher & lower effect.
Again, it was one of those things that took a while, just trying different curves & adjusting the various Points where needed.
Bear in mind that most of the hat's pieces haven't been Boolean together.
That's because I was designing it for machining, not for any rendering.
Mind you I have no experience with Rendering, so I'm not even sure if this model would be suitable for it or not?
Rendering is something I'd like to learn & understand, but at this point I'm concentrating on the modeling side of things first.
I'm figuring there's no point in knowing how to do a Render if you can't produce the model first?
Not sure if that's the right way to look at it or not, but figure I'm better to learn to crawl before I try running!
regards Colin
490.49 In reply to 490.48
In a sense, I come more from the rendering side than the making. (Carrara)
Anyway I did the hat band a different way!
I made another curve for the hatband about the level of the top of the lower piece. And, with the points , put a dip in the front edge. The two curves then lofted. Then I made a copy paste and reduced its size to .99 and raised it up a bit, doing similar for each of the layers.
The end result being that, when brought into Carrara for rendering, each of those different layers could have a slight variation in shade perhaps. Even put sweat stain effects differently for the layers as well.(I hope that makes sense!)
All good fun!
(Actually I did not save my results--just experimented to prove working principles)
490.50 In reply to 490.49
Here is an exagerated example to show the idea.
EDITED: 22 Nov 2008 by BWTR
490.51
Hi Everyone,
Thought some of you might be interested in knowing about this:
I've recently been using MoI to create the all the prototypes, tests & the finished Template files available from here.
http://fourth-axis.com/
http://fourth-axis.com/flipflopwax/
As most Jeweller's are already using Rhino to create their designs, so it was easy for me to Copy & Paste all the parts & curves that I'd created in MoI straight over into Rhino. :)
Then it was just a case of setting up Rhino's Layers to hold the relevant items. (looking forward to when MoI has it's own Layer system!)
regards Colin
490.52 In reply to 490.51
Nice work Colin, looks like a very helpful guide for people who want to dig into CNC.
490.53
Hi Everyone,
For those Jewellers looking at MoI, but aren't too sure, I've made a very simple MoI "Beginners" Tutorial that might help.
This ZIP file contains the whole Tutorial broken down into 3 parts, each as separate PDF files.
Hope it's of use, Colin
490.54 In reply to 490.53
Thanks Colin,
Now I have many moi tutorials ;)
490.55 In reply to 490.53
Nice contribution Colin!
Well done, clear and easy to follow.
490.56 In reply to 490.53
Thanks for taking the time to do this.
490.57
Hi Everyone,
Here's a ring design I've been doing for a customer to celebrate 40yrs of riding.
There's to be 3 of these rings made, each will then have the riders name engraved along the bottom of the band.
The design will be milled in wax & then cast in StgSil.
Used MoI for all of it except the actual deforming of the Brake & Clutch Levers to fit snug to the ring shape.
For doing that part I needed to use Cage Edit in Rhino4...looking forward to when MoI also has this feature.
I've only just started to learn about rendering, so here's some of my first tests using VRay.
Just uploaded these same pics to the Gallery
regards Colin
490.58 In reply to 490.57
Hi Colin, that's a very cool design, I'm sure that your customer will be very pleased.
It must be fun creating these kinds of personalized projects for people, since it will have sentimental value to them.
Nice conceptual motor bike ring!
490.60 In reply to 490.57
Nice one Colin!
I know a few bikers that would love one of these.
Keep 'em coming.
EDITED: 27 Jul 2009 by DANTAS
490.61 In reply to 490.60
Great stuff. Keep practicing the rendering. Having great product renders of your designs will be great
Tony
(aka HamSoles)
490.62
Hi Everyone,
Having seen other Members here doing various Sci Fi stuff, I thought I'd have a go at it also...
I remembered watching Gerry Anderson's UFO series as a kid & figured it might be a good starting point.
Did a quick search on the web & managed to find some Blueprints for the UFO model from the show.
Here's the relevant links for others that might be also be interested.
http://ufoseries.com/blueprints/index.html
Here's a link to a model kit that was for sale, this also helped as a reference.
http://amazingscience.altervista.org/ufomodelproduct.htm#
Here's hoping I've done it justice.
490.63 In reply to 490.62
UFO blueprints? Cool! :)
It turned out great.
Encounters!
Show messages:  1-4  5-24  25-44  45-64  65-79
