IGES importer difference in OSX 2.5 beta versus OSX 3.0 Beta
All  1  2-8
4897.2 In reply to 4897.1
Ok, sorry "Join" did allow my to join all of them at once as Closed Crvs.
Best regards
4897.3 In reply to 4897.1
Hi Stefan, there actually was not any change in the IGES importer between the first OSX beta and the most recent 2.5 OSX beta, IGES imports should behave the same in either one of those.
Hello Michael,
mmhh, this is very strange...I tried a second example and it behaves the same. As you can see on my screenshots in my beta 3 in comes in as closed curves, while in my beta 2.5 it comes in as curves only. But no big problem, since "Join" works after importing. Maybe i have a little ghost in my machine?!
Best regards
EDITED: 4 Nov 2016 by STEFAN
Size: 207.9 KB, Downloaded: 51 times, Dimensions: 948x444px
Size: 213.1 KB, Downloaded: 49 times, Dimensions: 949x445px
4897.5 In reply to 4897.4
Hi Stefan, so now that I stop and think about it and double check, I can remember now that there was an update to the STEP/IGES/SAT import/export library between those versions.
The 2.5 release has the newer library, I'm not sure if the change in behavior was intentional or not, I'll try to take a look.
4897.6 In reply to 4897.5
Same difference for V2 and V3 win versions.. FYI.
4897.7 In reply to 4897.1
Hi Stefan - re: difference in IGES import behavior from OSX 2.5 beta from the first OSX beta -
After much confusion on my part, I've got that fixed up now for the next beta.
There was actually a bug that was having a side effect of enabling your sphere.iges curves to come in as closed curves, and then when the bug was fixed that behavior went away. But I found out how to configure things so that the closed curve import will be enabled again for the next beta without it being just a side effect from a bug.
4897.8 In reply to 4897.7
thanks for taking the time to look into this. Much appreciated!
Best regards
Show messages: All  1  2-8
