consistency
 1-8  9-25
4894.9 In reply to 4894.7
Just to help clarify what I mean by "internal doubled end caps", you can see them if you select the outer cylinder surface and delete it:
Then these are the internal walls that I'm talking about:
There are 2 of those right there, one for each side end of your original surface.
You don't want to have that kind of thing inside there.
4894.10 In reply to 4894.9
Actually I guess you've got a little tiny bit of space there between the ends, but it's really pretty small - it would be better to either have a larger gap or make no gap and not have the caps.
I've looked a bit more closely at your text now and I can't find any problems with it falling apart, I'll probably need to know which particular area you're talking about for that problem.
It's a bit easier to see the text by deleting the outer surface like in the above image and then looking at it from that outer side rather than from the inside. Or also you might want to temporarily hide all edges (go to the Scene browser Types section and click the eye icon next to Edges to hide them all) so that the edge bleed through doesn't get in the way visually for that particular stuff.
4894.11
Michael,
This really isn't my issue.
My issue is that Moi sees the deformed shape as a solid (when no other software does).
When I export that solid to another piece of software the next piece of software finds a problem. If I can't tell in the Moi there is something wrong then it's a problem for me. It means I can't trust that aspect of the software, which means I can't send the file on to other people because they don't use Moi.
What I need is for Moi to see the same thing as other pieces of software.
So if moi says it's a solid then I would hope other pieces of software would see it as a solid. If moi sees it a series of surfaces then I hope other pieces of software see it as a series of surfaces. I don't care what it is (a set of surfaces or a solid) I just want it to be consistent.
What I uploaded is a demonstration of moi seeing both, the deformed and the undeformed, as both solid. but when I export the file and open it up in other software. The other software sees the deformed one as an incorrect open model.
Make sense?
thanks
Val
4894.12 In reply to 4894.11
Michael,
I'm attaching what I see in Rhino when I import the file as a STP.
The sphere pole errors are there and the letters are not lining up either. When I import the file as a 3DM into rhino it's fine. so there is something going on in the translation to STP from the Deform because this doesn't happen on the un deformed model when it is exported as a STP.
Val
EDITED: 30 Jan 2022 by VAL2
4894.13
Hello,
If this helps this is what it looks like when opened in SCE 2011+. The plate imports as a solid, there are some curves and there seem to be two holes in the outside wall of the ring. Once the holes are closed using the Repair Missing Faces command the item becomes a solid, but not a closed ring, it capped that micro gap internally with two faces to make sort of a ring with a micro split. There are inexact edges according to SCE, but I think that's a tolerance issue, nothing that is preventing the generation of the solids. What is interesting is that the file provided has the two internal faces of that sphere but not the outer ones.
Edges Test
EDITED: 3 Feb 2025 by OSTEXO
4894.14
I have kind of run into this too. When I sent our engineering dept simple extrusions to open with Inventor the other day they had to play with the import options for a while. This is what I was told.
"With the default setting the geometry imports as surface data. If I turn on the Auto Stich and Promote options prior to import, they import as individual solid bodies."
I don't know anything about Inventor (or any other solid modelers than MoI) but I would just assume a solid in one program would be a solid in another. Maybe it's more of a problem with Inventor than MoI.
4894.15 In reply to 4894.11
Hi val,
This is not correct though - if you load the exact 3DM file you posted into Rhino v4 and then select your deformed object, and then run the "What" command, it reports that the object is a:
"Closed solid polysurface with 232 surfaces."
So Rhino definitely sees it as a solid as well - it uses the same definition as MoI where a solid is an object that has every edge joined between 2 surfaces.
However, there are some glitches in the model in the pole areas in the deformed spheres, and some other programs when you do the import into them by STEP format or whatever, will probably try to analyze the object and make sure that it's actually structurally sound and they would then probably see that there is a problem with those areas.
Yes, like I mentioned previously I would like to add some kinds of diagonistic and analysis tools into MoI in the future. It is not an easy area to add though because it's a difficult thing to do a good UI for without just giving some highly cryptic feedback like "Error number 252".
This is happening already with importing it into Rhino.
I myself can't control what additional processes another program does to their imported geometry.
Most likely your other program is doing some kind of analysis of the imported object and deciding that although it has all edges joined it is not a proper solid and so decides to break it apart into surfaces instead of keeping it as a badly formed solid.
That's something that the other program is doing during some of it's processing, I'm not in direct control of what that other program decides to do.
As far as I can tell though, the root cause of your problem is like I've mentioned before that there is a bug in the deformer when deforming those sphere surfaces that have a collapsed down pole area in them. The deformed spheres are mangled in the small area near their poles.
Different programs may respond in different ways to mangled geometry.
4894.16 In reply to 4894.15
Michael,
Right, I said that already, if you load the 3DM file into Rhino it's fine but not everyone is able to view 3DM files. I need to export out a generic solid file. So if you export out a STP (from Moi) file the result is the screen grab that I posted. If you export out a STL file you will not get a water tight object and needs to be hand repaired. So yes the rhino screen grab that I posted is correct (I didn't fake it).
I'm not interested in diagnostic tools in Moi. I really like your approach to your software. It's why I use it. I think it's brilliant.
Simple, direct, uncluttered with specific tools. It really is a wonderful product.
I have said this already but I will say it one last time then I give up.
If you export out the un deformed object in any format every single package can read it as a water tight solid.
If you export out the deformed object in generic formats other packages come back with an error.
It's that simple.
There is something happening with your exporters and your deformer. There is no other possible answer.
You asked for people to report bugs. this is a bug.
thanks
Val
4894.17 In reply to 4894.12
Hi val,
The best way to move geometry from MoI into Rhino is to use 3DM format.
> exported as a STP.
That seems to be some issue with Rhino's STP importer - it must be deciding that those edges are not accurate enough or something like that.
Again, I myself do not have direct control over additional things that another program may decide to do to change objects when they import stuff in. Some programs may have some options to control their behavior about changing things, like some programs have options to "heal" geometry, which can be turned on or off, it's not unusual for that of additional processing to make things worse instead of better.
But you will certainly have problems with the sphere pieces going into other programs, those pieces are indeed mangled.
In the attached files I've modified the object to have the mangled sphere pieces removed and to make the gap between the end cap pieces a bit larger instead of barely skimming right over each other.
The attached STP file generated from that cleaned up object reads into both ViaCAD and Alibre as a solid, and MoI is also able to read it back in from that STP file as a solid.
There does seem to be different behavior in Rhino's STP import, that could be some kind of bug or limitation of some sort in the Rhino importer, I'm not sure why Rhino behaves differently than other programs in this particular case, you would probably need to contact them to find out more details about that behavior.
As you can see here, different programs may do different things with imported data.
Your request to make MoI work the same as all other programs doesn't really make sense because the built in assumption there that all other programs behave in one uniform way is not correct...
4894.18
Hello,
I'm curious what package your using to load in the STEP. I loaded your test file into MoI, exported to STEP, and directly opened the STEP file in SCE 2011+. It actually produces a better result than trying to open the 3DM file in SCE. Both items are solids on import, no repair required.
Test STEP
4894.19 In reply to 4894.16
You're going to need a non-mangled object in order to do this.
I've gone over this a whole lot of times already, but the root of your problem here is that the deform tool has made a messed up object out of those sphere pieces.
If you try to transfer the resulting messed up object into other programs, yes you are going to run into problems with it. You will have to remove those 4 deformed sphere pieces and construct them with some other technique in order to make a proper model which can then be exported to other programs.
Above I attached the result of doing that, and the resulting STEP file imports into both Alibre and ViaCAD as a solid.
Yes, again as I've written a bunch of times already this has to do with the mangled sphere pieces.
You are not going to be able to generate a properly formed STL file from the deformed sphere pieces, the surface or trim edges are messed up enough right in the pole spot and that will cause some kind of overlapping or otherwise messed up triangulation right in those spots.
Try exporting an STL from the above file where I've removed those sphere pieces instead.
Yes, I do also see that there is some problem in Rhino's STP importer with handling the text. That problem seems to be something particular to Rhino's importer, I tried both ViaCAD and Alibre with the above file that has the sphere pieces removed and got solids into those programs.
> It's that simple.
Yes, as I've explained numerous times the deformed spheres are messed up and you are not going to be able to get a proper transfer with that messed up model - you will need to remove those particular pieces of the model and construct them some other way in order to get good geometry that can then be exported properly.
In the file above where I have done that, the resulting STP file can be imported into other programs (other than Rhino) without errors.
Yes there is definitely a bug in the deformer with processing surfaces that have a pole in them. We've discussed that numerous times here and even in a previous discussion thread.
I don't see where the bug is in the exporter for this case though, as long as you don't try to export the mangled sphere pieces it looks like the export to other programs aside from Rhino is correct.
4894.20
Michael,
Yes I know you have said it many times but then you go off in some other direction which isn't what I'm talking about So I then try to bring it back.
Just to clarify,
I have no interest in the the test model other than to show what is happening.
I know the model is mangled and that you have stated it and I have stated it as well. the whole point is that the model is mangled. It is mangled because of the use deformer and the exporters. But I can't know that the model is mangled until I import it into some other software. if it is mangled the Moi should say that it is (as in saying it is a series of surface and not a solid)
I have no interest in Rhino per-say I was just using it as an example. I send out my models to people who are using solidworks. They complained about the models failing. So I have no interest in importing files into Rhino as 3DM files as that is not what I'm up to.
So it must also be Solidworks STP importer as well that has a problem
I also get problems with Freecad and importing the STP
I also get problems with 123D importing STP
I have in other files removed end caps and joined them I can go through and fix the files by hand. i know how to do that. but this is all beside the point.
I'm not asking for Moi to work the same as other software. I'm asking that when I export the file the file behaves correctly on export.
I originally asked a simple question "should I drop trying to use the deformer until it is fixed?" and it was answered by you in a round about way as "yes stop using it until it's fixed."
But then you have basically said there isn't anything wrong with it and it is all the other software packages importers that are wrong. which I am disagreeing with you about.
thanks
Val
4894.21 In reply to 4894.20
Hi Val, I'll try to explain it more clearly here.
> and the exporters.
It is mangled because of the deformer, not because of the exporter.
Once the deformer has made a mangled object then pretty much all bets are off as far as how other programs are going to deal with it.
This is not correct the mangled object is not just a series of totally separate surfaces, the mangled object is made up of joined surfaces but one area of its edge curve structure is messed up and it's got some kind of self intersecting squiggle back on top of itself right in the area of the pole.
This is where the additional kind of diagnostic tools that I was mentioning earlier would come into play - those could be some kind of tools that you could activate that would try to examine the model and look for corrupt or messy geometry that is going to cause problems.
But I don't know where you're getting this idea that the deformed object (the mangled one) is just a series of surfaces instead of having joining - that is not correct. If it ends up that way in some programs during their import, that is something that the importing program is deciding to do to the object when it processes it, and it's probably doing it in response to the model having a messed up structure in the poles.
The ones with the mangled spheres in them? Yes, I expect that you will not be able to get a proper output with those 4 mangled sphere surfaces in them.
Do you mean with the above model where I removed the spheres, or are you talking here about problems with importing the object that has the messed up sphere pieces in it?
That won't be able to happen if your object is damaged in the kind of way that the deformed sphere pieces are.
For this case in order to get a good export you will have to remove those pieces and model them in some other manner in order to get a non-mangled object.
You should avoid it _for spheres_ you can use it for other stuff, like in the model that you posted if the messed up spheres are removed then the resulting STP file can be sent _as a solid_ to other programs other than Rhino which seems to have some other problem in its importer.
> you about.
The other importers are not wrong in having problems dealing with the messed up sphere - that is definitely a problem in the geometry.
You will not be able to get a proper export of those mangled spheres, they are messed up!
If those particular 4 surface pieces are removed then you will be able to get a good export to it - the STP file that I posted above goes into ViaCAD and Alibre fine and I also tested writing an STL file with it and that seemed to be ok too.
I don't know how many times I can go over the same thing, here is the clearest way I can describe it:
There is definitely a bug in MoI's deform commands when dealing with surfaces that have a collapsed-down "pole" type arrangement to them.
I am in no way denying that this is a current bug in MoI's deformers - in fact we already discussed this exact same bug in a previous thread.
The deformed result of such surfaces is messed up and will cause all kinds of numerous problems including problems with export, problems with further boolean calculations, etc....
In order to have a proper model which can be used for pretty much anything other than just a rendering, those mangled sphere pieces need to be removed and replaced with better geometry for just those pieces, before you will be able to get a proper export of that model into other CAD programs.
EDITED: 6 Feb 2012 by MICHAEL GIBSON
4894.22 In reply to 4894.20
I guess the part I don't understand is - if you know that the Deform tool is making a messed up object for those spheres, why is it that you're trying to export that messed up object and expecting for the exporter to produce a good result from it?
There's a saying: "Garbage in, Garbage out" - if the exporter is given some kind of mangled object to export, it doesn't understand how to unmangle it, the solution has to come in the process that generated the messed up object to begin with.
Given a messed up object different programs will behave in all sorts of different manners - some may try to repair it (like SpaceClaim seemed to), others may give up or in the process of giving up may instead try to just salvage what they can make sense of which could result in a bunch of separate surfaces.
In the future I would like to add some tools to analyze objects for different ways that they might be mangled. I'm not sure when that will happen, it's a lot of work to plan a good UI for that. In the shorter term I do expect to work on fixing up the deform tools so that they won't construct a mangled object for deforming spheres.
4894.23
Michael,
I'm saying regardless of the spheres the the exported STP fails. I've attached my own demo. there is a cube with it. there are no sphere shapes what so ever. If you try to combine the two in free cad the operation fails.
If you open it up in Rhino it still has problems with the letters
if you open it up in 123D the deform model doesn't show up.
I don't have Solidworks so I can't test it out in that.
I know it has to do with the deformer. That is obvious.
I wasn't saying it was a series of surfaces what I was trying to say was I would like it if Moi expressed some kind of clue that the function had failed just like it does now when you do a bad Boolean operation it turns the solid into a series of joined surfaces. You can find the problem within moi when you do a bad Boolean operation or do a poor joined surface. That was all that I was saying. No more no less. Just a suggestion.
Val
EDITED: 14 Jul 2021 by VAL2
4894.24 In reply to 4894.23
Hi Val,
So it seems to load it ok though in Freecad? Isn't Freecad in some kind of early Alpha release right now?
Why is it that you don't consider a boolean failure in Freecad to be a bug in Freecad?
It could certainly be possible that there is something about the deformed geometry that it does not like to handle very well, like some kind of lesser degree of accuracy between how UV curves and 3D curves relate to one another. It may be possible to do some tuneups in the deformers to help with this.
For 123D I'd recommend trying SAT format instead, that may work better.
I tested importing your STEP file into Alibre and it seems to go ok into there.
ViaCAD seems to get stuck, I didn't wait for it to finish maybe it would after a while.
I also tried with CoCreate and it also seemed to go in ok there too.
It also works fine reading your file back into MoI as well.
Unfortunately it's not a particularly unusual thing for different kinds of CAD programs to have different sorts of peculiarities or problems with imported data. For some programs you may get a better result with a different file format.
I don't see how just blowing up the deformed result into a bunch of separate surfaces would really give you a good clue as to what went wrong. Most likely it would just lead to the question "why is my result a bunch of separate surfaces, I did not expect that", without really conveying any particular information.
It's pretty tricky to do a good quality UI for actually making that kind of communication happen.
4894.25 In reply to 4894.23
For your Autodesk product, use the ACIS kernel....
I have several other packages that read in the "Solid" also, though I can analyze it down to having some issues...
Val, I think your answer is there will be some tools LATER, to analyze geometry differently, so you can see how things will react further down the road.
Show messages:  1-8  9-25
