Shelling troubles...
 1-5  6-22
489.6 In reply to 489.2
Thanks for explanation and "repairation" ! -Petr
489.7
...one point of order :)
How do you feel about command that could remove unnecessary control points from underlying surfaces like Rhino's _ShrinkTrimmedSrf command? Sometimes it is hard to keep "neat" surfaces using all boolean powerful commands.
For example the button's upper part is composed of 325 control points in comparison with 160 points after shrinking surface in Rhino.
Petr
489.8 In reply to 489.7
Hi Petr,
Re: ShrinkTrimmedSrf
Well, the difficult thing with stuff like this is not the command itself, but rather how to integrate it into the UI.
I don't have a particularly good spot to add sort of less frequently used things such as this right now.
So what I did is I added a new ShrinkTrimmedSrf command for the next beta, but there isn't any UI to activate it by default, to use it you'll have to set up a keyboard shortcut or put it on one of your custom menus.
489.9 In reply to 489.8
Yep, it is necessary for you to hold your respect as a carpenter... :) Something what we discussed in the past... measure twice, cut once...
On the other hand, it is very cheering that there are still commands which can be extended... for example Extend itself... hehe..
489.10 In reply to 489.9
:) In the meantime I don't have any problem with adding "hidden" commands for stuff like this.
489.11 In reply to 489.2
>> After fussing around with extracting trim edges, trimming some of the ends off and untrimming and retrimming surfaces, I got this (model attached):
This reminds me of another post where you were talking about untrimming but I can't find it... Could you explain (again ?) what's "untrimming" and "retrimming". What is it useful for and how do you do that ? A bit confused as there's no "Untrim" command in MoI, right ?
Looks interesting as it seems it's a technique to detect or repair problematic surfaces.
Schbeurd
489.12 In reply to 489.11
Hi Bernard,
Probably this object repair tutorial: http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
Or also this: http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
Untrimming means removing the trim curves from a surface. Once trim curves are removed, the original surface (which is still there "underneath" all the trim curves) will be restored.
Then "retrimming" means just to trim (Edit/Trim) that large restored surface to a new set of fixed up curves.
It is useful for a couple of situations - sometimes you may want to kind of "erase" cuts that have been made on a surface because they weren't really in the desired place, as with that first tutorial above.
Another use is to clean up the messed-up results from operations that didn't do a proper job of things due to calculation bugs, like in the shell example in this thread. When you look at the corner there, the edges on the object are all a mess, pieces are sticking out where they shouldn't be, etc... To make a good quality object, messed up edges like that need to be repaired. This usually means to extract the existing trims as independent curves by Copy/Paste, then edit those curves (trim them with each other or whatever), and then erase trim curves on the surface and trim the surface with the fixed up curves.
It is built in to the "Delete" command - you can select trim edges and then hit Delete to remove them.
But there are a couple of restrictions - the edges to remove cannot be joined to other surfaces, select the object and do Edit/Separate if necessary.
Also to make it work you must select all the edges for an entire boundary loop. Surfaces can have one outside trimming boundary that trims away the exterior of the surface, and multiple interior boundaries that cut interior holes. Each boundary can be made up of multiple edges and to remove them you have to select all the edges for a boundary. For surfaces closed in one direction like a cylinder this also means the seam edge, it is part of the outer boundary loop.
If you just want to untrim everything on a surface, select one edge and do Ctrl+A / Select All, and then hit delete.
489.13 In reply to 489.8
<<Re: ShrinkTrimmedSrf
Well, the difficult thing with stuff like this is not the command itself, but rather how to integrate it into the UI.>>
First, I'd like to reiterate that I highly value and appreciate your primary goal
to keep MoI's UI, simple but highly effective and user-friendly.
It's one of the things that I find so innovative and appealing about MoI.
Having said that, I think that as designers new to NURBS gain
experience and see the potential for more sophisticated surfacing techniques,
and as more and more Rhino users finding themselves preferring to be in the MoI modeling
environment, we can anticipate a need for some of the less frequently used surface editing
tools that we're familiar with from Rhino such as ShrinkTrimmedSrf, " surface matching for tangency"
and probably several other features that you've invented or will invent, :-)
So what I'm trying to say is, the problem of where to put them, will call for a solution.
I use a few keyboard shortcuts in Rhino, but they're for tools that I use regularly...
I don't know about anyone else, but unless I see or frequently use a tool, I can forget it's there...
so if it doesn't have some kind of presence on the interface to remind me once in a while, I forget to use it.,
I find myself not even using aliases and tools that are exclusively keyboard activated..
If you want to keep MoI as an entry level CAD program and also have it be useful to more experienced users,
perhaps you can have a "basic" mode with the default workspace that looks and functions as the MoI we
are now familiar with, but then as new tools are developed and implemented you could add in the option
to turn on an "advanced mode" with tabs that would stay folded
up when not being used...or flyout menus for a 2nd tier of advanced tools, or like in Rhino, a pop-up middle
mouse button that you can customize with an assortment of tools on a floating toolbar that will
dock in place or else just stay open on a temporary basis.
Maybe even implement the option to turn on a very thin and unobtrusive top menu bar like Rhino has, for the advanced mode which
can be accessed with the mouse or by the keyboard? ex. (alt +F, then another letter for a particular function)
I don't know really.... everyone has their preferences and I'm just kind of thinking out loud, here. :-) The thing is, I really like the simplicity
of MoI's "look and feel" !
-Jesse
EDITED: 11 Jul 2007 by JESSE
489.14 In reply to 489.13
Hi Jesse,
> <....> .or flyout menus for a 2nd tier of advanced tools,
I'm thinking it will probably end up with something like this eventually, some kind of "Tools" popup menu where I can stick a bunch of less commonly used stuff without it making a big impact on the top level UI.
I've thought a little bit about having a "More..." button inside of some palettes that could be used for this.
It's a little clumsy but for tools that you don't need to access very frequently it is ok for them to be in a more clumsy location. It's the frequently used tools that have to remain more uncluttered and available at the very top level.
I'm not really leaning so much towards an Advanced UI / Basic UI switch, because even if you need to do some "Advanced" things it doesn't mean that you don't need to do a lot of more basic things more frequently anyway. So having less clutter is still really valuable even for "Advanced"...
But it will take a while to experiment with different ideas to come up with a good one. Usually I will have to make prototypes and try a few different ways before settling in on a good method. It is always surprising how much work it takes to make a "simple" UI for things.
489.15
Hi Michael and Jesse,
Well, I am accustomed to having quite austere interface in Rhino and using aliases solely, but in MoI I have got used to calling commands by the big-big buttons and it seems very natural to me. ( I'd still be interested to get a way of defining more than one-letter shortcuts, though. )
I guess the size of button is the reason for natural workflow with UI since I can start moving a mouse cursor exactly towards the particular button/tab and click it with only cursory glance at the side pane. On the other hand, I have adapted Help menu for me by adding new command/script items like ScaleArray and so forth. But it appears to be too clumsy and I often chase after specific item for a while before picking the one. So menu ( without big-big icons :) is somehow uncomfortable to me...
I think the command palette - with proper header name - which would be collapsed on default and would collapse itself after clicking on a button inside it, could be reasonable for less commonly used commands. If there wasn't space enough in the side pane, other palletes would collapse/expand appropriatelly so layout of the side pane would look identically before/after using those commands.
Btw, from my point of view the File menu come under a group of less commonly used commands, but there is a list of recently used files so I guess it would be difficult to handle it in a different manner...
Petr
489.16 In reply to 489.15
Hi Petr,
Yup, the big button size is a key factor. They're not just big to make them easier to look at for beginners, but also for everyone, experts and beginners alike, to be able to more quickly utilize them.
This is described by Fitts' law: http://en.wikipedia.org/wiki/Fitts'_law
Originally I made those buttons big to help make it easier to click on them with a pen tablet, which is sort of a bit more shaky than a mouse since it is harder to hold perfectly still. But this is one of those areas where tuning something for better targeting with the tablet also helps out for targeting with the mouse as well. I've been lucky that pretty much all of the tablet-oriented design stuff has turned out to be mouse beneficial as well.
Teeny tiny buttons in UI is kind of a pet peeve of mine. Especially on some laptops that have high density screens, it is amazing how tiny many buttons on other applications are.
That's definitely the plan for the future addition of entire groups of new functionality. Like dimensions and annotations will have a "Dim" palette that is collapsed by default.
But there is still a problem that stuff that is added to a palette has to be in some kind of a group that contains more than one thing in it. If there are a bunch of palettes that only have one or two things in it, then the palette headers aren't providing any real savings over having the buttons somewhere up at the top level.
Sometimes the biggest difficulty is finding a good grouping for stuff - for example ShrinkTrimmedSrf is difficult to place right now.
The collapsing part of this is implemented right now - you can see this if you shrink the window down (BTW I just found and fixed a bug where the mouse cursor doesn't switch to a sizing cursor when you are on the edge of a non-maximized window. But it still will still size right now if you grab there anyway despite what the cursor looks like) so that there isn't as much vertical room. Now when you activate a palette, other ones will collapse to try and make space and prevent the scroll bar from appearing.
I had thought a few times about making File be a tab on the side pane instead of a pop-up menu type thing, but yes the recent file list on it makes it pretty natural to have as a pop-up menu. It also just seems somehow natural to have as a menu because of similarity to "old fashioned" UI systems that have a menu bar.
489.17 In reply to 489.16
Have you try to use Moi with a "vocal command" for call functions?
So no need to press button : just drawing on screen !
Maybe it's more speedy?
(I have never used but see it on some computers' show)
489.18 In reply to 489.17
I haven't tried it. I would probably get a sore throat from talking all day long...
489.19 In reply to 489.18
Maybe... but avoid a hand cramp !
Choice is difficult :D
489.20 In reply to 489.16
>>The collapsing part of this is implemented right now - you can see [...] when you activate
Surely, I knew about it. But other part of described palette handling after clicking on button lying in the palette "marked as rarely used" is important part as well. It was a crucial thought of my previous reasoning. Now, palette handling can be characterized as self-expanding/other-collapsing. What I meant it was to make a things upside down (for less commonly used tabs/buttons) - i.e. self-collapsing/other-expanding_to_previous_state to restore it.
I really hope the scroll bar never appears to me... hehe... It would imply there is something wrong with UI - too many commands, palletes or something like this...
...see http://www.3designjewel.com/flash/discover/parametric/parametric_court.html
Petr
489.21 In reply to 489.20
Don't worry - having to use scroll bars to get to the UI is another big pet peeve of mine.
There are cases where they are necessary, but for MoI this should always be in cases where there is only very limited space available, like if you have shrunk down the window size or are working on a pretty low resolution screen.
I don't expect to use a scroll bar for typical basic UI access.
489.22 In reply to 489.12
HI Michael,
Yes, it was the second message. Thanks for the links. I didn't notice the first one. Some useful information there too ! ;-)
And thanks for the additional explanations.
Show messages:  1-5  6-22
