New Mac OSX public beta Jan-31-2012 available now
 1-5  6-25  26-45  46-65  …  86-103
4879.6 In reply to 4879.5
thanks Michael :)
4879.7 In reply to 4879.6
Hi Michael
In this OSX version, where do I copy scripts, I like using the CustomDistance script.
Cheers, Steve
4879.8 In reply to 4879.7
Hi Steve,
Right-click on the application and choose "Show Package Contents" - that will then open up a Finder window that is browsing the directory structure in there and then go to drive_c/moi/commands - that commands directory is where you can copy plug-in commands like CustomDistance.
4879.9 In reply to 4879.7
Hi Michael, I just tried it. It's wonderful to see the native OS X file dialogs. You also seem to have fixed this CMD-TAB app switching bug. I wasn't able to reproduce it.
When I started the app I saw this warning:
I was brave and allowed it but I wonder what this is and if I can dissallow it.
Thanks a lot for the new version,
Martin
4879.10 In reply to 4879.9
Hi Martin, hmmm I don't really know what that is about - MoI itself does not try to contact anything over the network. WineskinX11 is part of the porting infrastructure that I'm using to make things work, maybe it is using some kind of socket connections between different pieces.
Or it may have something to do with this anti-hacking protection mechanism thing that this version has on it since it's more like a trial version and does not require a license key.
If it's that second thing then in the final release version that won't be present.
For now I guess you'll need to hit "Allow" though. It looks like you only need to do that once though, it doesn't bother you any more after that does it?
4879.11
If Wine(skin) is anything like Parallels, Vmware etc, I guess this is just the Wine VM core asking for the normal connectivity to the network that your Mac will have so that things like browsers etc and any program that needs to be accessible from anywhere other than your host Mac.
4879.12 In reply to 4879.9
Hi Martin, I guess from what I can see that is complaining about some of the methods that MoI uses for communicating between some various sub programs that it uses for different tasks.
You may see another one pop up that says something about moi_osx_funcs.app - that's the piece that implements the native file dialogs.
So if you see those firewall warnings pop up you'll need to hit allow on them for MoI to be able to function properly, and I think once you have done that once it seems to remember that and won't bother you again.
4879.13 In reply to 4879.11
Hi Chris,
Wine is not quite the same kind of system as Parallels and VMWare - Wine doesn't actually run a full "virtual machine" - it's more like a compatibility library that translates Windows calls into their unix equivalents.
It doesn't really emulate a full machine environment, it only does anything when MoI makes a Windows system call.
Parallels and VMWare are pretty different - they actually run a full copy of Windows in a completely virtualized environment.
4879.14 In reply to 4879.13
Seems like I can turn that off.
I went to System Preferences > Security > Firewall > Advanced and turned on "Block incoming connections" for WineskinX11
MoI starts without problems so it seems to be not required to allow incoming connections.
I guess this message shows up only if the OS X firewall is activated and you start MoI for the first time.
I think I also saw this message with the previous Beta because there was a second WineskinX11 entry in the Firewall settings. Also set to "allow". I blocked both.
4879.15 In reply to 4879.1
What is the process to resize the whole window? I'm not able to by clicking and dragging lower-right corner.
---update----
Force quit and then launched again. Works OK now.
4879.16
Almost makes me wish I owned a Mac :-)
4879.17 In reply to 4879.14
Michael... You are unbelievable! Moi looks amazing on OSX, It feels like you developed a native OSX app!. Everything is very snappy, viewports are smooth and fast, there are occasional display glitches when e.g. turn on the browser or switch viewports, but that is not even annoying:) I have one of these "27 inch iMacs and MoI rocks:) hehe I am very happy man! Thank you.
4879.18 In reply to 4879.17
And the ability to have another MoI window open and copy and pasting between is awsome!!
Thanks a lot Michael,
it's working smooth so far!
Best regards
4879.20 In reply to 4879.15
Hi Paul,
> ---update----
Please let me know if you run into this resizing problem again.
Also right now resizing the window is a little stuttery/glitchy and I'm going to see if I can tune it up a bit.
4879.21 In reply to 4879.17
Hi olio,
I'm glad it is not feeling too out of place for you!
I think having the native file open and save dialogs helps quite a bit.
Great! Yes, that's one of the best advantages of this porting method - MoI's own program code runs directly and so it runs at full native speed when doing its own calculations.
> annoying:)
Yup, this hiccup happens when a 3D viewport gets resized - I'm going to be looking into it to see if I can fix it up, but at least it's only a cosmetic problem and not something that really gets in the way of actually doing stuff.
4879.22 In reply to 4879.8
thank you Michael.
spent about 2 hours with it last night, touching up some models I thought I had completed :)
worked fine for the simple stuff I'm doing.
Cheers, Steve
4879.23
Don't work for me.
Wineskin Error.
"ERROR! Launching wineserver failed! No new wineserver PID found!"
I enabled and disabled "Wineskin Winery" in firewall from System settings. I don't know what to do more. Please help.
4879.24 In reply to 4879.23
Michael,
I spent some time with this last night. The basic functions seenm to be working well for me. I will try some more complex work later.
Thanks a lot for this...
J. Tucker
4879.25 In reply to 4879.23
Hi artisanicview,
> Don't work for me.
> Wineskin Error.
Do you possibly have some kind of restricted permissions set on your system, especially on your temp folder?
If so then that could cause problems like this - this probably means there was some problem setting things up in /tmp
You also might try doing a system reboot which will clean out your /tmp folder and maybe that will help.
But if you have done some kind of lockdown process on your machine's tmp folder you may need to set that back to its original permissions in order to get MoI to run.
Show messages:  1-5  6-25  26-45  46-65  66-85  86-103
