Pulling my hair out, problem using Boolean Diff
All
1-2
3-6
Michael Gibson
31 Jan 2012 (3 of 6)
4878.3
In reply to
4878.2
Or I guess the other way you could do it would be to make the recessed areas slightly larger so there was a little bit of open space there where their corners run into each other rather than each corner touching the other right along a single edge.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
stevecim
31 Jan 2012 (4 of 6)
4878.4
In reply to
4878.2
thanks , Michael
I'm working in mm how small a gap can I make, would .01 mm work?
Cheers, Steve
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
31 Jan 2012 (5 of 6)
4878.5
In reply to
4878.4
Hi Steve,
Yeah that should likely be ok.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
stevecim
31 Jan 2012 (6 of 6)
4878.6
In reply to
4878.5
making sure there where gaps between object did the job.
thanks. Michael.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-2
3-6
