3D corner help
All  1-8  9-11
4867.9 In reply to 4867.7
Hi Tony, does Steve's tip help? I'm still not really sure that I understand exactly what you've been asking about.
Like Steve mentions, if you want to have 2 pieces that look like they come from one continuous thing, it tends to be easiest to model it as one bigger piece and then cut that up into pieces rather than modeling each piece all on its own.
You can do that kind of cutting by drawing in a side profile and then using the Boolean difference command to cut your large solid by the curve - that will slice the solid up into 2 separate solids. The "Crown of clubs" video tutorial does that at one point as well.
4867.10 In reply to 4867.9
I hope the new picture helps. The block of wood is a 2+x6" piece of wood with the recoil pad screwed to it. The wood will be fastened to the table top and one side profiled and then turned over for the other side. The wood needs to be contoured like the black recoil pad. Until now I have been removing much of the wood on a milling machine and then finishing the process with a table top belt sander.
Hope this helps
Tony
Size: 141.6 KB, Downloaded: 57 times, Dimensions: 640x480px
4867.11 In reply to 4867.10
Hi Tony, so I guess you just want to model the basic curved outline of the shoulder pad?
I'm still not entirely sure if I understand, but if you want to construct a block with a curved outline in MoI then the way you would do that is to run the Draw curve > Freeform > Control points command here:
Then go to the Front view, and draw a profile curve that has the shape you want, something like this for example:
Then you can construct a solid block from that profile curve by selecting it and running the Construct > Extrude command here:
That will produce a result like this:
In order to make a good match with your shoulder pad you will probably want to take a picture of it from straight above and then place that image into MoI as a background image so that you can see it in the viewport and use it as a tracing guide when you are drawing the curve.
To place a background image you use the View > Image command, as shown here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4506.2
Please let me know if I still did not understand what you are trying to do.
Show messages: All  1-8  9-11
