Create fillet
All  1-4  5-9
483.5 In reply to 483.4
Seems your frame rectangle has some internal intricated complex forms :)
So filet can't follow the entiere curves!
From your existing frame you can make that Select all "up surface facetts" / delete it / Select all / Make planar / Now select the new "facett up"/ Filet works :)
EDITED: 18 Mar 2007 by PILOU
483.6 In reply to 483.4
Hi Jani, yes as Pilou mentions the extra internal edges of your top and bottom surfaces tends to confuse the fillets.
In general the more edges that you have running together at any point, the more likely it is that the filleter will get confused. It doesn't take too much to confuse it...
I've attached here an updated version of your frame that will now fillet.
To make this version, I selected the surfaces from the top side and deleted them, and then did Construct/Planar to fill in the resulting hole with a single simple planar surface. Then repeat on the other side.
483.7 In reply to 483.6
Funny I just wrote the same :D
483.8 In reply to 483.7
Seems like you're getting pretty used to using MoI! :)
483.9 In reply to 483.8
Maybe an alert message "Somebody post during your last visit"
"Would you like see it before posting?" will be cool :)
PS I am not an expert but begin to understand some little things about theses crazzy nurbs :D
Show messages: All  1-4  5-9
