Create fillet
All  1  2-9
483.2 In reply to 483.1
Hi Juan, can you please post the .3dm model file for your fillet problem?
For doing a fillet, there are different results depending on the selection.
If you select 2 curves that are not edges, you will do a curve fillet between them.
If you select a single curve that has corners (for example a rectangle), you will do a curve fillet on the corners.
If you select edges, those edges will fillet.
If you select surfaces of a joined object, all the edges that belong to that surface will fillet.
If you select an entire object, all its edges will fillet.
The last case if you select 2 surfaces that are separate surfaces not joined to anything else - in this case it will do what is called a surface/surface fillet.
If you can post a model file it would help me undertand what is happening.
483.3 In reply to 483.2
This must be "post it" on the monitor screen :)
483.4 In reply to 483.2
Hi Michael, I have also a lot of problems with fillet on frame.It works only if select only one edge and just on one.
Jani
483.5 In reply to 483.4
Seems your frame rectangle has some internal intricated complex forms :)
So filet can't follow the entiere curves!
From your existing frame you can make that Select all "up surface facetts" / delete it / Select all / Make planar / Now select the new "facett up"/ Filet works :)
EDITED: 18 Mar 2007 by PILOU
483.6 In reply to 483.4
Hi Jani, yes as Pilou mentions the extra internal edges of your top and bottom surfaces tends to confuse the fillets.
In general the more edges that you have running together at any point, the more likely it is that the filleter will get confused. It doesn't take too much to confuse it...
I've attached here an updated version of your frame that will now fillet.
To make this version, I selected the surfaces from the top side and deleted them, and then did Construct/Planar to fill in the resulting hole with a single simple planar surface. Then repeat on the other side.
483.7 In reply to 483.6
Funny I just wrote the same :D
483.8 In reply to 483.7
Seems like you're getting pretty used to using MoI! :)
483.9 In reply to 483.8
Maybe an alert message "Somebody post during your last visit"
"Would you like see it before posting?" will be cool :)
PS I am not an expert but begin to understand some little things about theses crazzy nurbs :D
Show messages: All  1  2-9
