Network surface
 1-9  10-29  30-49  50-69  70-89  90-91
481.30 In reply to 481.29
Tricky indeed and show the power of the function rail Revolve! + Editing move points :)
EDITED: 17 Mar 2007 by PILOU
481.31 In reply to 481.29
Looks good, Michael. The rail revolve is probably the appropriate tool at this point for this type of shape, then tweak the control points to get the desired contour. My moise is beginning to take shape. ;-) Okay, one final question, where can I find the extract curve tool? Is there any? I trimmed the mouse with a cutting curve as shown and projected the bottom curve on a plane. Is this the way to do it? Now I want to extract those curves in prep for loft tool. Also, is there a way to flatten curves in one op?
(This is not the final shape of my moise ;-) I just want to make sure I have all the tools available before drawing the final one. Thanks guys.)
481.32 In reply to 481.24
>>But yes a side effect of this method is you have to place
>>more profiles to control the shape along the central line.
...and what about third method for sweeping as described here?
[quote:integrityware]
These three images show three different Shape Scaling techniques we use. First is streatching where we basically streach or shrink along the vector between the rails. Second is uniform scaling where the entire curve is scaled uniformly. Third utilizes a third rail to define the scaling height in direction purpendicular to the line between the two rails.
[quote]
Petr
481.33
Okay, I have figured out how to extract a curve: select the underlying curve and copy. Anyway, this is my preliminary sketch of my moise. ;-) This is just the beginning of my MOI adventure. ;-) I hope you'll welcome more suggestions. I've got plenty.
(..nice illustrations there tyglik, and very informative, too.)
481.34 In reply to 481.32
@prtr : how do you obtain your link above
I am here and cant' go elsewhere :( (is it my navigator?
I have find it ;)
Page bottom of this :)
http://www.integrityware.com/products/SOLIDS++/technology.html
EDITED: 18 Mar 2007 by PILOU
481.35 In reply to 481.33
Yup, that's the basic extract technique.
Another way to make a quick duplicate is to select the edge and then hold down control and drag off a copy of it. But Copy + Paste can be good since it completely preserves the location of the object.
It's looking pretty nice!
Certainly! That's how things improve! :) Of course some things may take a while before they can be implemented...
481.36 In reply to 481.31
Yeah, at the moment this seems like the best way for this particular shape. But I definitely want to make this work better through a curve construction technique as well instead of relying on surface point tweaking. Network surface is probably the one, but I'm also pretty interested in fixing up Sweep so that it would work better for this.
Actually, Network surface will only really be better for doing the full object but for doing the half object network surface will have some similar problems as sweep in that there will still be some cross-sectional rotation especially in the last sections where things come together to a point.
Running through this has given me an idea to try for sweep, which is to see if all the profiles are on parallel planes, and if they are then create each in-between new cross-section on that same plane. This would eliminate rotation of the profiles and should result in something that can be cleanly mirrored.
It is nice if it is possible to model a clean half of a model, it is sort of less hassle to tweak the shaping by editing a half a curve instead of worrying about editing a symmetrical curve and keeping it symmetrical.
One way is to turn on points for the curve, select all the points and use Transform/Align - then pick your alignment location in the front or side view with horizontal alignment.
At some point I would like to add a one step project function that didn't make you turn on points, but I haven't quite figured out where to place that in the UI, like whether it should go in some sub-function of align or have to be its own separate tool.
481.37 In reply to 481.32
Hi Petr, yup, this is yet another thing on the list that I have been wanting to add. It seems like it should be a pretty good way to add additional control over the sweep shaping.
I think it is not too hard to add, I'll see...
481.38 In reply to 481.30
Sometimes when you see that things are arranged to have poles, that can be kind of a clue that rail revolve might work well as a base surface...
The nice thing about rail revolve is that the surface it generates inherits the exact same control point structure as the curves that are used. This is a lot different than some other functions like sweep for example, which go through a type of fitting process that generates a lot of extra points.
So the results of sweep are not very friendly to manipulate with surface points, because each surface point that you move only changes a small region of the surface - this makes it hard to move the points around without causing bumps and lumps.
When you have a smaller number of surface points like rail revolve generates, that makes it easier to tweak them and not get lumps.
In this case one part that I didn't mention is that I added one control point to the profile curve so that the surface would have a good point to edit in one of the wider areas - the original curve was actually too sparse and it wasn't easy to tweak the surface to conform to the profile without having one more point in there.
Every once in a while it can work to switch your perception of what is a profile and what is a rail, like in this case for rail revolve it involved a reversal of thinking more of profiles in a radial sense around the poles, rather than profiles moving along slices of the object.
481.39 In reply to 481.38
The funny thing is that with simple function + astuteness (adding control points...) some situations can be yet resolved :)
481.40
One more thing. As shown on the images below, all those edges in yellow are the result of trimming using cutting edges (lines/curves). Those lines are supposed to have small gaps. Is it possible to add another trimming option where you could specify a gap as well as the extent of it, instead of drawing two offset lines first? Just wondering. If not, forget about it.
481.41 In reply to 481.40
Unfortunately it would be really difficult to make this work well, especially in corner areas where two of your trimming lines come to a sharp corner, and also in junctures where there are several of them coming out from one point.
So I don't think it will be possible to do this anytime soon. Maybe some day...
481.42
Thanks, Michael. Good thing is there are enough tools to achieve the desired result. I was also thinking of an auto kind of trimming when it comes to lines/curves to be used in bool/trim ops. Two intersecting lines, for example, offsetted on both sides, then the original lines disappears as well as unwanted lines such as those inside the intersection. I think Moi should have some kind of an embedded programming tool like Autolisp or something so that users can participate in adding some little tiny functionality even if only when it comes to 2d shapes.
Anyways, this is still a draft. As they say a journey begins with one step. It's not necessary for me to render it lifelike. What's important is knowing that the tools are there to achieve the bigger magical picture.
481.43 In reply to 481.42
Added to the special thread gallerry :)
481.44 In reply to 481.42
MoI uses JavaScript as this kind of embedded programming language. It's actually used quite extensively to control how each command works (when to hide and show controls, etc..) - the script file for each command is inside the \commands subdirectory.
But it takes a lot of effort to document how to use MoI in combination with a programming language. The documentation and support work far outweighs just having the embedded language capability. I don't expect to have enough time to do proper documentation of this type of scripting for the V1 release of MoI, but it is something that I would like to focus on more in future versions.
481.45 In reply to 481.22
I'm not sure what I'm doing wrong...I did this before and still can't figure it out! I checked Enable HTML,
when I look at the preview it's OK, so I hit Apply and the spellchecker comes on.
I cancel the spell shecker and hit OK, but the image does not appear.
Jesse
481.46 In reply to 481.45
You must when Edit your post
"Enabled with auto-line-breaks"
erase the special caracteres around your image address and all will works fine !
I had same problem before :)
481.47 In reply to 481.46
Yeah, it is possible it converted your angle brackets into plain text angle brackets at one point.
That would look something like this: <img where the brackets around your image have been replaced with an escape code for showing a less-than or greater-than bracket.
If that happens, you've got to go in there and remove those escape codes and put just a < or > character.
-Michael
481.48 In reply to 481.47
Modeled in MoI, rendered in Flamingo.
-Jesse
EDITED: 22 Mar 2007 by JESSE
481.49 In reply to 481.44
"But it takes a lot of effort to document how to use MoI in combination with a programming language. The documentation and support work far outweighs just having the embedded language capability. I don't expect to have enough time to do proper documentation of this type of scripting for the V1 release of MoI, but it is something that I would like to focus on more in future versions." --Michael
I sure understand. At some point you have to, Michael, imo. Perhaps at version 2.x(?) Not that it is badly needed at the moment. I've heard of Moi before and grabbed the then current beta which was months ago. It's grown pretty fast. Arrays are now there and the booleans and fillets work perfectly and it no longer crashes! But it will even grow faster if there is some kind of audience participation. It's what made AutoCAD the way it is today, its open architecture. It's still Autodesk's flagship, it's main bread and butter. Now it's got Maya and Max. You may be be able to buy Adobe someday, hehe. And Corel. Or Newtek. ;-)
Show messages:  1-9  10-29  30-49  50-69  70-89  90-91
