Network surface
 1-10  11-30  31-50  51-70  …  91
481.11 In reply to 481.9
Hi blenddoodler,
> I don't know how you could mold this kind of shape with the current tools.
You can use a sweep with 2 rails to construct that kind of a shape with the current tools. To do it, select the section curves and then run Construct/Sweep, then select the 2 other curves as the guide rails.
The profiles will be swept along the guide rails to create a surface.
Let me know if you want more info on how to work it.
481.12 In reply to 481.11
Hihi I have made it during your post :)
481.13
Okay, how about being able to split curves? In AutoCAD it's called "break" command with the "F" option. Which means after invoking 'break', it asks for the first pick point along any point on the curve, or it may be outside of it. The second pick point will be the extent of the part of the curve intended to be cut out. The option 'F' just meant that the second point is the same as the first pick point. In short, it splits the curve in two. Rhino has a straightforward break feature and it's called exactly what it does -- "split", in which you can split a curve in any number of divisions. If you look at the mousewire in the previous post, three curves that are supposed to form one smoothed curve were done separately. Obviously, this is not exactly an accurate way to do it. Am I making sense?
481.14 In reply to 481.13
Hi blenddooler - the equivalent of this in MoI is Edit/Trim.
Select your curve you want to cut into pieces. Now run Edit/Trim.
At this point, you can either select any other objects that you want to slice the curve with, or push the "Add trim points" in the options area, which will let you pick slicing points on the curve with your mouse.
When you have finished picking cutting points push "Done" (or push enter or right-click in a viewport).
Then there is one more stage - this is where you pick which pieces you want to discard or keep. If you want to keep everything, push "Done" (or enter/right-click) and all pieces will be kept which is the equivalent of Rhino's Split command.
481.15
Okay, one last question for now. If you look at the mirrored half of the mouse in my second post, the joined surfaces aren't exactly tangent, thus have kink. Any suggestion how you could smooth it in MOI?
Thanks for the replies. I'll have to learn MOI in its entirety before asking any more questions. I'll be back.
481.16 In reply to 481.15
MoI does not yet have an easy way to edit surfaces later on to smooth them with one another.
You can still get smooth results, but you have to make sure that your curves are set up before your sweep so that they produce results that don't have a crease.
Usualy this means carefully placing the second control point inside from the end of the curve, which controls the tangent direction at the end of the curve.
Also, sometimes it is easier to get a smooth result by setting up the sweep using a full curve (mirror and join the profiles first) for all the profiles instead of doing it in pieces, then your result is generated all in one shot instead of mirroring it.
If you would like to post the curves here, I could show you how you would tweak them to produce smoother results.
481.17
Hi Michael. Yes, you'll have smooth surface results if your curves are set up properly even if you apply mirror later on. Or you could forego mirroring and draw the whole curves. The advantage of mirroring is that tweaking is less painful in that you only have to deal with half of the object especially the parts that are farther away from the mirror line. In a way I think this is another workflow alternative to have: draw your curves haphazardly then mirror or edit the curves with tools such as join, match curve or surface tangent, etc.
You mentioned joining curves. I tried it, how do you smooth out that kink where the the two curves meet?
481.18 In reply to 481.17
Yes, certainly this is good to have as another option - I expect to add this type of "Match" functionality in a future version. But since MoI V1 won't have it this workflow alternative won't work in MoI for the time being.
For this you can turn on control points, select the point at that juncture and delete it.
But what I was really thinking of was join it after you have already carefully drawn it so the tangents of the pieces align.
481.19
Yes, MOI's sweep tool actually does the job for these types of shapes. I did the whole curve tangency thing by joining the mirrored halfs of the curves, deleted the points at the juncture, cut them again in half and there you go a smoother surface result. If you want it smoother at the mirror line you might want to add more profiles like in the nose of the mouse. I don't know if this is precise. But I'm still experimenting.
481.20 In reply to 481.19
Just a quick note - if you want to tweak those curves, the sweep should dynamically update.
But the mirrored part won't update automatically - this is because history updating is not turned on by default for the results of mirroring. Some operations (right now including all transforms) don't have updating turned on by default because it can sometimes be confusing for doing basic things when a bunch of other stuff changes.
However, you can turn on updating for the mirroring - to do this, select the mirrored half, and run Edit/History and choose "Enable update" - once you have done that, if you edit one of those curves it will update the sweep, which will then in turn update the mirrored part.
Here is a tutorial that I wrote earlier on making a Japanese bath tub which uses a similar half-edit type thing: http://moi3d.com/forum/index.php?webtag=MOI&msg=402.9
Also, I'm not certain but I think you can still get creases with the sweep that you're doing there, because there will be a type of rotational twist happen in between the profiles as the ends move along the rails at sort of slightly different speeds.
The way you can absolutely guarantee that you will have a perfectly smooth result is to use mirrored+joined profiles, and instead of splitting the profile, keep it intact and mirror that side rail over to the other side and use that as the second rail instead of the central rail. When doing it that way the profiles will not have rotation happen to them since the rails are mirror images of each other and points match up perfectly between them with no "slanting" as the sweep moves along.
481.21 In reply to 481.20
I can't wait for network surfaces in MoI. Very cool!
This brings to mind something that seems like the next logical progression.
Would it be difficult to implement environmental mapping
to check for for surface continuity?
I guess this belongs under feature suggestions... :-)
Jesse
EDITED: 11 Apr 2007 by JESSE
481.22 In reply to 481.21
Hi Jesse - quick note on editing forum messages, there is a little control under the message when you edit it that says something like "use HTML", you have to turn that on for your <img> to work right.
This is turned on by default for the initial post, but I forgot to update the edit post page to turn it on by default. Some day I'll get a chance to tune up this forum a bit and just make that HTML by default as well, and probably add in a button for inserting images.
re: environment mapping / zebra type stuff - definitely want to add this in the future at some point, but it won't be ready for V1.
481.23
Hi, Michael. This is what I got so far. All profiles are mirrored, then joined. I observed that there has to be as many profiles to take on the desired curvature as the central rail, which is not used in this case, when looking at the right side. Is this what you meant? I think I'm getting close, but there might be a better way.
EDITED: 17 Mar 2007 by BLENDDOODLER
481.24 In reply to 481.23
Yup, that's what I meant - this way you are guaranteed to eliminate any creasing.
But yes a side effect of this method is you have to place more profiles to control the shape along the central line.
This one does look like a good candidate for Network surface, so hopefully that should help out here when it is ready.
One other thing you can try is to use the rails to generate the smooth tip instead of swinging profiles downward for the tips. By this I mean having 2 rails like so:
Those rails collapse down to a point but this can be more well behaved in certain ways because all your profiles can stay completely upright and there isn't a big rotational swing when moving between any 2 profiles. That's just another possible configuration...
Maybe it is possible for me to beef up the sweeper a little bit to avoid the twisting/rotational problems that happen with the half-sweep in cases like this... Might be a bit difficult to do right now though.
481.25 In reply to 481.24
Michael, the two rails are adjoined this time as you suggested. (The middle rail is for construction ref. only.) I don't know what's happening here. Seems that adding more profiles just creates a wavy surface. What do you think?
Be back tomorrow.
481.26 In reply to 481.25
Hi Blenddoodler, I think this is related to a sort of "ease in / ease out" blending that happens between profiles.
Maybe I should turn this off and do a more simple straight linear transition, or give a control for turning it on or off.
Can you please post your model file, I can give a try over here with this turned off and see if that is what is causing it.
481.27
Attached is the file below. BTW, are you sure this is the right way to do it? I mean adjoining rails creates unsightly poles when rendered. What do you think? Be back tomorrow...
481.28 In reply to 481.27
Hmmm, well those lumps are mostly caused by the shape ease-in/ease-out blending, but I can't easily just turn it off because it causes a different kind of micro-bump where they kind of abruptly change (attached).
I'll have to think about different ways to make this better.
Network surface is looking better and better for doing this central spine control... I guess that will likely be the main way to handle this better.
Well, there are a couple of good things to it - it keeps all the sections staying vertical throughout the sweep so in one sense that takes out some additional variables. Also the way that NURBS algorithms are usually set up, it is more of a standard thing to have a pole than it is to have a corner of the surface where the corner is bowed out to have opposite pointing tangents.
But it is just another approach, if the other way works for you then that's fine.
481.29 In reply to 481.28
I was experimenting with some other possibilities other than sweeping.
Here is one totally different way - here I took just one rail and one cross-section and instead of sweep I did a rail revolve, with the curve that used to be the sweep rail as the revolve profile, and the one that used to be a sweep profile as the revolve rail, with the axis running down the pole.
Then I turned on surface control points and switched to the front view and tweaked them vertically until the profile matched up with your original spine curve pretty well.
481.30 In reply to 481.29
Tricky indeed and show the power of the function rail Revolve! + Editing move points :)
EDITED: 17 Mar 2007 by PILOU
Show messages:  1-10  11-30  31-50  51-70  71-90  91
