auto boolean extrude
4806.1
Is an automatic boolean union possible with 'extrude'?
For instance, I might want to change the length of a framing member ( or a bunch of them) in a house design. Now I use extrude face to do that and then have to run the boolean union to make one piece. It is just a couple of clicks but it does take extra time ... particularly when there are a lot of pieces involved at one time.
cheers,
eric
4806.2 In reply to 4806.1
Hi eric, yup that's on my "todo" list to try and figure out some kind of option for having extrude automatically combine its result into a base object.
But I also want to make it possible to move faces and have surrounding faces extend, I think that would actually be better for what you are describing. It's pretty involved to make that work well though, so I'm not exactly sure when it will happen but it is definitely on my radar.
4806.3 In reply to 4806.2
Thanks Michael, that's great.
and Happy Solstice and the coming of the light again.
cheers
eric
4806.4 In reply to 4806.2
Hi Michael G. Were you thinking of something like the push/pull and grabber tools in ViaCAD 2D/3D v8?
Michael T.
4806.5 In reply to 4806.4
Hi Michael T - yeah something like that but I'm not so sure that it needs to have any additional special tools, maybe just dragging on a face or using the Transform > Move command with a face selected could do it.
Like I mentioned though, there is a lot of manipulation of the objects behind the scenes that has to happen for that kind of editing.
4806.6 In reply to 4806.5
Yeah, that would be a lot of work! Keep up the good work Michael G. I'll keep supporting MoI as much as I can!
Michael T.
