Generative design
All  1-5  6-8
4805.6
What Michael says is true. When I found grasshopper I was very exited because of the things people do with it, but its because it is good doing repetitive and progressive tasks and paneling; that makes a model look very complex. Like Michael said it needs a lot of planning and it is useful when you are going to try different things around one model, and then before you start you plan which things will be manipulable and base your definition on that.
I don't know the other programs people mentioned but If you think parametric modeling is for you I think GH is a good solution because it works in rhino and you can just copy paste things from MoI and vice versa. GH has a lot of great things inside for making complex models and for playing around in the design phase and to mention a couple more features it is easy to use compared to other software and it has a great community almost as good as this one.
Currently I'm working on a model that has a lot of parallel planes that morph from one form to another. That can be done with a sectioned loft but I'm using GH because: Im not sure what the final form will be nor i know what the final spacing between planes will be because its not constant. Using a traditional approach it can take a lot of time and I can get tired of making a new model each time i think of a change. Here GH become useful. Any way I always draw in MoI the things I need and then copy them to rhino, and in previous works, after making all I want in GH i bring the model to MoI for the final touches. In complex models MoI and GH make a good team.
4805.7 In reply to 4805.6
I have experimented with both GC and Grasshopper. Check this link for comparison (http://designplaygrounds.com/deviants/rhino-grasshopper-vs-generative-components/). To my limited experience, Grasshopper is much easier to learn than GC .
Revit or Project Vassari from autodesk is also another tool that has some limited capability for generative design. check this website (http://buildz.blogspot.com/).
All of these applications require some knowledge of scripting if you want to do very complex forms with parametric functionality. I still prefer to use MOI for conceptual design. It is fast , easy use and enjoyable. In my opinion you can probably be able to do some fairly complex forms specially with available scripts and two new added feature (flow and twist commands)
-sharif
4805.8
Hi! Thank you everybody opinion. I like your points. Actually I concentrate liveable things not that strange things from star wars :), So my aim to construct some structural elements determined upon logical geometry shapes such as curtain walls, frames etc. with many detail. For example If a screw fix changing needless to construct all of them. As well as there are many other things to exploit such as equation based graphics formula such as sun path diagrams, linear heat transfer figures and so on. That node based script engine is not just only crazy things, I believe. I just want to say it would be cool to see in moi. happy new year!
Show messages: All  1-5  6-8
