fillet help
All  1-16  17-19
4802.17
Most it`s a Scale problem, when you export "step" in your scene you can try fillet units between 0,1 and 0,005.
Or you can try to edit it with press/pull. Press or pull a patch a little bit: (0,0001).
And Try to Fillet again.
Size: 657.6 KB, Downloaded: 29 times, Dimensions: 1881x1092px
4802.18
4802.19
One thing that helps with fillets, is to avoid unneccessary edges in your construction. I find that when I have built a curve structure, it is often best to join it, then carry out a rebuild on it to make one single curve. The original joined curve will create edges if you, say, extrude it, where the joins were. The rebuilt curve won't.
Show messages: All  1-16  17-19
