Illustrating
All  1-3  4-13
4793.4 In reply to 4793.3
Hi Michael and Marc
Thanks for the suggestions. Actually I have a lot of software I have purchased over the years but I have been on a personal quest to find ways to make modeling simpler, less expensive and clear. My wish to create a book for small houses anyone can build themselves is part of the same impetus. I do a range of architectural work but my passion is affordable housing, energy efficiency and renovation and retrofitting. I hope to create a portfolio of construction details (illustrations) anyone can understand without a lot of experience at reading drawings. Many manufacturers are doing fine work in this direction.
So, I now use MoI almost exclusively for modeling and for most 2D drafting, as well. Octane is producing decent renderings ... fast and low cost ...though for most of my 3D detail work screen prints from MoI are clean and clear enough. Draftsight is free and a very adequate 2D program for dimensioned layout plans.
I'm attaching a preliminary (and incomplete) illustration that I just did as an experiment with a small renovation project I am currently working on. The object was to work with inexpensive and efficient tools.
All modeling with MoI
Quick render with Octane (needs a CUDA equipped graphics card).
Lettering with Inkscape (a free Illustration program) saved as a .jpg file for small file size (using PhotoShop Elements). I think I will be able to use Inkscape for annotating construction details. (it does not save as .jpg files ... a pity as this takes another step).
By the way, SimLab Composer is great with 3d pdf creation and a good, low cost rendering tool, as well.
I know Michael is working on a .dxf export for MoI ... that will help a lot to export to a 2D drafting program.
So far I have not found ViaCad 3d very useful for importing MoI 3dm files ... it seems to miss significant parts in the translation (maybe I am not careful enough). I have been trying out ViaCad Pro 7.
ProgeCad is a good translator for AutoCad files but moderately expensive and Draftsight is free and does a pretty good job on .dwg files in both directions.
Sorry this discussion is straying away from MoI topics a bit ... but it is now my primary architectural design tool (After more than 30 years since setting aside my pencils and drafting table).
I have been looking for a magic bullet to take it from MoI to completion but have not found it yet.
cheers,
eric
Size: 59.6 KB, Downloaded: 221 times, Dimensions: 792x509px
4793.5 In reply to 4793.4
Hi Eric, Try to use STEP to go to Viacad.
4793.6
Yes, ViaCAD 2D/3D v8 can do 3D dimensioning. I have not played around with annotation in 3D yet.
Michael T.
4793.7 In reply to 4793.4
Hi Eric, this looks like a great project, I would be interested in that book.!
Hope you keep us posted on it's progress.
Marc
4793.8
Eric,
not that MOI isn´t a great piece of software, and I personally haven´t done any architectural designing with MOI, but from just a quick glimpse at your visualization I can tell you that you definitely want to look into the free version of Sketchup. Combine that free version of Sketchup with the free version of Doublecad XT, and you have a pretty much very useful package for simple modeling. Sketchup models are imported very quickly into DCad, and you can then very quickly generate layouts and dimensioned views and sections.
MOI is way more versatile for creating mechanical things, and I love the more organic approach you can take with it, but it´s something completely different to what I as an architect would actually use for day to day work.
4793.9 In reply to 4793.8
Hi Mike ..
Thanks. I have tried Sketchup many times and even bought an early version of it after being a beta tester. I know it is a good program but have never felt very comfortable with it. I will check out Doublecad XT.
Thanks again,
eric
4793.10 In reply to 4793.9
Hi ..
Here is the type of illustration I was wanting to do when I started this discussion.
This is done with MoI .. a high res screen capture and then on to Inkscape ... finally to PhotoShop to convert to a .jpg file.
All I did with Inkscape was to erase a few lines I could not hide adequately with MoI and then the hex keys and the text,
It turned out to not be a difficult job and it gets the information across.
cheers,
eric
Size: 137.3 KB, Downloaded: 289 times, Dimensions: 1053x745px
Size: 145.1 KB, Downloaded: 136 times, Dimensions: 765x990px
4793.11 In reply to 4793.10
Here is another illustration of a foundation detail variation.
The model is completely MoI using the high resolution screen capture Michael developed the script for.
The symbols, pointers and text were added using OpenOffice Draw ... a free program. It turned out to be the simplest to use illustration program I have found for free.
For me the days of 2d architectural details are about gone .. MoI makes it so simple.
cheers,
eric
4793.12 In reply to 4793.11
Eric, that illustration looks really good!
And I can immediately see the difference between the u.s. and Europe ;) The corner where the vertical and horizontal part of the foundation meet is at 90 degrees, allowing potential water to sit there, whereas over here in Europe that corner usually needs to have the isolation lead water away from the foundation at with two 135 degree angles http://www.tektorum.de/attachments/hochbau-konstruktion-planung/175d1107940878-bauko-2-schaliges-mw-fundament-bla.gif
But I digress :lol
I must admit, now I am tempted to start sketching up details in MOI ...
4793.13 In reply to 4793.12
Yes, Mike..
Yours is a better detail for getting water away.
Yes, MoI is a great tool for this.
thanks,
eric
Show messages: All  1-3  4-13
