shortcut: select everything with the same name.
All  1-3  4-5
4780.4
cool thanks, this really speeds up my workflow. I noticed if the script only selects object which are visible. Could this be changed so that it would select all object and make the hidden objects visible?
4780.5 In reply to 4780.4
Hi nos,
Yup, this is possible by making a small change to the script, here is a version that should behave like you're asking about:
script: /* Extend selection to same names */ var names = new Array(); var objs = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name != '' ) names[obj.name] = true; } objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name != '' && names[obj.name] ) { obj.hidden = false; obj.selected = true; } }
Show messages: All  1-3  4-5
