shortcut: select everything with the same name.
All  1  2-5
4780.2 In reply to 4780.1
Hi nos - here is a script which you can paste in as the command part on a shortcut key for that. When triggered, it will go through and select any objects which have the same name as one that is already currently selected.
script: /* Extend selection to same names */ var names = new Array(); var objs = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name != '' ) names[obj.name] = true; } objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name != '' && names[obj.name] ) obj.selected = true; }
4780.3 In reply to 4780.2
lol Ask it and Michael fix it. :-)
Nice script thanks...
Peace,
Rich_Art. ;-)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat + MoI
4780.4
cool thanks, this really speeds up my workflow. I noticed if the script only selects object which are visible. Could this be changed so that it would select all object and make the hidden objects visible?
4780.5 In reply to 4780.4
Hi nos,
Yup, this is possible by making a small change to the script, here is a version that should behave like you're asking about:
script: /* Extend selection to same names */ var names = new Array(); var objs = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name != '' ) names[obj.name] = true; } objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name != '' && names[obj.name] ) { obj.hidden = false; obj.selected = true; } }
Show messages: All  1  2-5
