A Drone and Rail sweep advice
All  1-8  9-11
4773.9 In reply to 4773.8
BTW as you said making that little outset with straight edge allowed me to bevel to 0.2.
I was under the impression that rounding edges actually helped filleting.
4773.10 In reply to 4773.9
Hi Steve,
If it's a tight bend that's basically resembling a fillet, it's usually best to actually let it be filleted as well.
If it's quite a bit broader of a bend than the fillet radius that you want then it's fine, but tight bends make things difficult for the filleter because basically a fillet has some similar qualities to an offset that it wants the fillet to hang off of the surfaces at a particular offset distance of the radius that is being used.
When you have something hanging off of a curve and the thing is larger than the curvature of the bend in the curve it causes this kind of bunching/self-intersecting type effect which then makes things difficult for the filleter in those areas:
4773.11 In reply to 4773.10
Oh great, thanks for the explanation
Steve
Show messages: All  1-8  9-11
