Is there a 64 bit Version of MOI ?
4760.1
Is there a 64bit version? I downloaded the trial, and it's 32bit - is there a 64 ?
~~Deuce
4760.2
There isn't and from what I've heard there is not going to be a 64 version any time soon, but 32 bits is enough 99% of the time cause MoI makes a very good use of your resources.
4760.3 In reply to 4760.1
Hi Deuce, yup what Ed says above is correct - there is currently only a 32-bit version. At some point in the future there may be a 64-bit version but not anytime soon, there are actually a lot of other feature areas that will help with things for large model handling more than being 64-bit, stuff like instances for example.
Even the 32-bit version does benefit from running on a 64-bit OS though, MoI is able to access about twice as much memory on a 64-bit OS than on a 32-bit OS.
