Violin surface???
All  1  2-15
4743.2 In reply to 4743.1
Hi riko - generally you will want to focus on making an initial surface that's more like square sheet and then using booleans or trimming to cut the outside of it off to make the actual rounded boundary edges.
See these threads for some descriptions:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2021.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=3618.1
4743.3 In reply to 4743.2
Super!!!! Thanks Michael!!!!!
How to make this form? This make Marc Tellier, MoI user...
EDITED: 27 Nov 2011 by RIKO
Size: 38.5 KB, Downloaded: 84 times, Dimensions: 556x438px
4743.4 In reply to 4743.3
Please help!!!
My love MoI!!!
4743.5 In reply to 4743.4
http://liutaiomottola.com/components.htm
Use a spiral for the top curve?
http://thefree3dmodels.com/stuff/accessories/violin/21-1-0-247
Used free meshlab to convert to Obj
Use the free MoI converter Obj23dmWireframe converter to convert obj to 3dm
The model look pretty flat.
http://www.karlroyviolinbook.com/pdfs/Append682-3.pdf
Pretty good site here: http://www.kcstrings.com/anton-krutz-geometry (fibonacci based:-)
Some good cross sections to work with?
You can use MoI view image to "trace over" a picture, to assist in selecting the "right" curves and lines...
EDITED: 10 Aug 2013 by BEMFARMER
http://liutaiomottola.com/myth/scroll.htm
"...typical violin scroll. When I (*HE*) copied Rabut’s scroll for the diagram above, I made use of a nice computer graphics algorithm for drawing approximations of scrolls by Taponecco and Alexa. Very simply, the algorithm approximates spirals by displaying them as tangent circular arcs, with their size relationships described by an arbitrary function. When I copied the violin scroll I did it using tangent 90° circular arcs of whatever size was needed to fit the section of the spiral I was working on. That the relationship of the lengths of the radii of these arcs could not be described by simple multiplication is a clear indication that the spiral of a typical violin scroll cannot be described by any logarithmic spiral. It is highly likely.... "
Trace 2D image of a good scroll using MoI arc cont command repetitively for short portions of the scroll...
ps (Myself) knows nothing about violins.
http://liutaiomottola.com/construction/Scroll.htm
http://www.gutenberg.org/ebooks/28252
EDITED: 27 Nov 2011 by BEMFARMER
4743.7 In reply to 4743.3
Hi Riko, the scroll part is probably going to be one of the more difficult areas, you are probably going to have to draw several guide curves and probably use several sweeps to make those parts.
There is a thread here where Marc has various images for the progress on making that particular model, maybe looking through them will help give you some ideas:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1050.1
http://zhurnal.lib.ru/m/muratow_s_w/violin_design.shtml
Lots of guide curves.....
It is in english. :-)
4743.9
Thank you ,very very match!!!! Guys...My prerelies.))
EDITED: 28 Nov 2011 by RIKO
Size: 788 KB, Downloaded: 108 times, Dimensions: 1999x987px
4743.10
Great work klickoff,
The scroll was definitely the hardest part, I had another try at modeling it last year.
It's not as good as I would wanted it, another avenue I wanted to explore for the head is Subd with a moi base model.
But it's a real good exercise in exploring Moi's sweeps!
For the head it seems that less profiles works better.
Marc
4743.11 In reply to 4743.10
Great, Great, Great Marc. Thank yuo very match!!!
4743.12
Really nice. What renderer?
4743.13
Magnificent work!
I'm very impressed.
4743.14
No problem Riko!
Shaun, if you ask about mine, they were made with octane.
Marc
4743.15 In reply to 4743.14
very cool.. nice wood shader by the way.
Peace,
Rich_Art. ;-)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
Show messages: All  1  2-15
