Mac OSX v3 prototype available now
 1-17  …  58-77  78-97  98-117  118-137  138-157  …  178-180
4737.98 In reply to 4737.97
Hi phlatt5th,
> A few more questions, I would like to use some of the
> scripts on the resource page is that possible?
Yeah pretty much all the scripts should work exactly the same in the OSX version. The only one that probably won't work is the import point file one since it uses a Windows system component for reading a text file in. At some point I'll provide some text file services for scripts so that can be made to work as well.
But other than that one script I think every other one ought to work, please let me know if you find any that don't.
> especially the spacebar fullscreen under cursor one
It should work - please let me know if it doesn't.
> How would I get it to remember the full screen on launch?
It doesn't seem like the window size will stick right now, that's probably the only setting that doesn't. I'll look into that.
4737.99 In reply to 4737.98
>It doesn't seem like the window size will stick right now, that's probably the only setting that doesn't. I'll >look into that.
is there a window menu on the menu bar when running moi?
if so, is there an a window->zoom menu choice?
if so :) , try clicking the green button at the top left of the moi window (maximize) then go window->zoom..
you should be able to resize the window to your liking now and it will be remembered across sessions.
[lots of ifs in this :) ..but this does work in certain other osx apps that can't remember their size]
4737.100 In reply to 4737.94
Thank you Michael.
Alt+Q script: /* Exit MoI */ moi.ui.mainWindow.close();
works fine and closing the app by cmd-Q also remembers the settings.
It takes about five seconds until Moi actually closes by the way. But I guess thats because X11 is also closing in the background.
I'm glad you provided a straightforward way to customize the MoI Icons.
EDITED: 27 Nov 2011 by MARTIN3D
Size: 163.2 KB, Downloaded: 107 times, Dimensions: 1153x959px
4737.101
Hello Michael
I really want to test this version, but I have the license version 1.
I did not have version 2, because I have no license "windows" on my Mac.
But now a Mac version, I dream !!!!!! I buy as soon as possible!
Thank you in advance
Vincent
De : Objet: Date : À: Répondreà:
Michael Gibson <moi@moi3d.com>
MomentofInspiration1.0-OrderInformation
26 mai 2008 14:10:21 HAEC sajous.v@............... MichaelGibson<moi@moi3d.com>
Dear Vincent, Thank you for your purchase of: (1) - Moment of Inspiration 1.0 - Full Version
Your download link:
http://www.plimus.com/..............................................
Your license key: VER1-...............................................
4737.102 In reply to 4737.101
Hi Vincent - at the moment you need a v2 license to use the OSX beta. That's the same as with the v3 beta release.
But if you have v1 you can purchase the v2 upgrade license instead of the v2 full version license to get v2.
Within another month or so I'll release some kind of public trial version of the OSX version that won't require any license at all, so if you can wait for a little bit you'll be able to use that version to test it without purchasing anything new at all.
How is the stability of the OSX version?
Is anyone seeing any crash problems at all?
So far I have had 0 reports of crashes for this version, I just want to make sure that's actually the case and not just because nobody is using it extensively yet.
Also if you've previously been using the regular Win version on Parallels or VMWare, how does the performance of the 3D display compare between that and the new version?
4737.104 In reply to 4737.1
Hey Michael,
Thank you! Thank you! Thank you! Thank you! Thank you!
Just downloaded it and played a little. Works smoothly as the PC version!
Info:
Macbook Pro 2.4 ghz
OS X 10.6.8
-Dooki
4737.105 In reply to 4737.103
I have no complicated models like the motorcycle Frenchy Pilou shows in post 12 of this thread and I have never used MoI natively under Windows.
All I can say that I feel no difference in UI performance between using MoI in OS X and in VMWare.
One thing that takes "forever" though in VMWare and OS X are Sweep operations.
Does the following give a result under Windows?
A 0,5 mm diameter circle sweeped around a 1000 mm long helix with 5 mm diameter and 1000 turns calculates several minutes but gives no result in MoI VMWare and MoI OS X.
When I shorten the helix to 100 mm it takes about 50 seconds of calculation before the result is displayed.
Am I asking too much from Moi by sweeping a circle around 1000 turns?
Size: 325.6 KB, Downloaded: 85 times, Dimensions: 1464x910px
4737.106 In reply to 4737.105
Hi Martin,
> around 1000 turns?
Actually yes - by the standards of NURBS modeling which creates a truly curved surface, that kind of 1000 turn tube is extremely complex.
One thing you can do though with such complex surfaces is to change the display density to be rougher - see this previous post on the settings to adjust:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4558.4
The default settings for MoI generate a pretty high density display mesh, which for simple models makes the model look really nice but for a really high complexity tightly curved surface like you're trying to create the default settings will generate a quite high density display mesh.
The kind of complex single surface that you're trying to create in this case is kind of unusual in NURBS modeling - if you're trying to do something like that as a render effect you probably want to do that in a rendering program which may have some method of generating a pretty low polygon result along that curve instead of the kind of highly accurate result that NURBS modeling is focused on.
Basically when you are building NURBS models, the system is tuned towards high accuracy in all operations - the surface that you are generating there is refined until it is within 0.001 units of the ideal result. That kind of accuracy helps a lot for making precise and manufacturable models, but in a case like this it also creates a result with heavy data in it.
What kind of end result model are you trying to build that has a 1000 turn coil like that in it?
It is possible that MoI is not the right tool for the particular job that you're trying to do - if you want something that has a 1000 turn coil in it and you don't care about the actual accuracy of it a polygon modeling tool is probably a better tool for that case.
If you adjust the display density it may help some, but that particular sweep example is a pretty unusual case, in more regular types of sweeps you shouldn't see such a long delay.
EDITED: 27 Nov 2011 by MICHAEL GIBSON
4737.107 In reply to 4737.105
Hi Martin, so for something like that you'll probably need to do the 100 turn sweep and then piece 10 of those together rather than trying to do the 1000 turn sweep all in one go.
The way sweep works is that it starts out by trying to construct the sweep using only a few sample points and then tests the accuracy of the result. If the result is out of tolerance more sections are put in and the process repeats.
With a 1000 turn helix, you're looking quite a high level of iterative refinement needed until it will hit the 0.001 unit accuracy level.
Sweep does not have any way itself to recognize that there is a type of repeating pattern here, but you can take advantage of the repetitive nature of the pattern yourself by constructing a smaller sweep and then arraying it rather than doing one huge sweep.
But anyway because the way sweep works is by refinement of a fitted surface until a high accuracy level is obtained, it just does not work very well to do something with that kind of complexity in just one single surface sweep.
A polygon modeling program would have a much easier time of it because they generally don't care about hitting a specific accuracy level at all, so they'll do things like just move forward by some fixed increment along the curve and not even test accuracy of what that produces.
Sometimes in a case like this the NURBS modeling focus on generating accurate results can have some side effects, like in this case needing to do a smaller section that gets copied rather than doing it all in one go.
4737.108 In reply to 4737.107
Thanks Michael for the detailed answer and insight. I'm a 3D beginner but I see.
I tried to model an 1 meter long threaded rod. Because it didn't work I used a simpler example.
Changing the Mesh angle to 25 helped and the example sweep actually displayed eventually. But your suggestion of joining several short pieces is the way to go for me. Should I use Join or Boolean Connect for this?
4737.109 In reply to 4737.108
Hi Martin - if you have pieces that have edges that are directly on top of each other then you can use Edit > Join. If you're going to do that you would want to delete the end caps of the pieces (or not generate them in the first place by disabling the option in Sweep) before copying them so that the edges to join are open and not already connected between 2 surfaces.
Boolean Union would probably work too, but the booleans generally try to do a kind of more complex task of finding intersections between objects and then cutting them up and removing some material.
If you don't actually need any material to be removed like when you've got surfaces sitting next to one another with their edges actually touching each other then Join will glue those together with a lesser amount of computation than the booleans.
If you've got something like 2 objects that are pushing partway though each other, and you want to combine those, then that's the kind of thing where you would definitely need to use Boolean Union since you would want some intersections between the different surfaces to happen.
4737.110 In reply to 4737.103
Seems pretty stable on the iMac with the specs i gave before. I did what I (a newbie) would consider a fairly complex (study see attached). A flow with a high number of spherical solids to a twist to a boolean. When I tried to boolean all at once the it failed to produce the desired result however when I boolean in small bites the the end was successful. The old shortcuts and the scripts I tried work. script for quit Alt+Q or Cmd+Q works well and it holds my changes except for the full screen for which I just click the green button. Will keep testing on other machines.
4737.111 In reply to 4737.102
oK Michael
wait and see...
thanks
Vincent
4737.112 In reply to 4737.83
A 2.5 OSX release sounds good to me.
Look forward to seeing the public trial version
atb
Paul
4737.113 In reply to 4737.18
Hi Luis, earlier you had reported that it doesn't work on your machine:
> Tried it on an my black macbook with Lion (OSX 10.7.2) but the views
> don't work. only get a big pixelated black ellipses on all of them. doesnt
> matter if I switch to single view either. :(
> any suggestions?
Could you please go to the "About this Mac" > System report > "Graphics/Displays" section and post what that screen there says about your display chipset?
Over here I just got in a 13" MacBook Pro with Lion 10.7 which has "Intel HD Graphics 3000" as the display chipset, and I had thought it would help me to test and debug the display problem that you're seeing on your machine, but on this machine the display is working fine without any of the problems that you are seeing.
This is good news for me on one hand that not all Intel chipset systems have a problem. But on the other hand it leaves me wondering what is the difference between this system and your system where it does not work properly.
I guess one difference is that you've got Lion 10.7.2 and this one has just Lion 10.7 - maybe there are some new video driver problems with the update, I'll try to update and see what happens then.
4737.114 In reply to 4737.113
hey, that is good news!
college students are going to love you :)
4737.115 In reply to 4737.114
Hi Jeff,
Yup, it should help a lot of people out having it work on the low-end machines.
That Intel chipset is not exactly a high performance chipset for 3D graphics though, and so it probably will be more suited for more medium level complexity scenes and not particularly high detail modeling. But it should work fine for quite a lot of kinds of models.
The question is why does not it not work on Luis' machine... Maybe there was some kind of driver glitch in the 10.7.2 update, I'm downloading that now to see if I can repeat it under 10.7.2 - it could be something simple like the updated graphics driver not reporting that it supports some particular function when it actually does do it.
4737.116
OMG... I was just away for a few weeks and now a OSX Beta Version? I just nearly fell off my chair when I read this. Michael has to win some kind of best-customer-listener award or something... :D
*EDIT* Seems to work very well for me on 10.6.8... I'll have a closer look later.
EDITED: 30 Nov 2011 by SW03
4737.117 In reply to 4737.113
Ok, well I updated this 13" MacBook Pro with the Intel HD Graphics 3000 chipset to Lion 10.7.2 and MoI is still running fine on it...
So Luis, any information you can give me about what your graphics chipset is or if you possibly have any system extensions/haxies running would be helpful.
Also if anyone else is running the MoI OSX beta with an Intel graphics chipset, please let me know if it's working for you or not.
Over here at least it seems to be running fine on it.
Show messages:  1-17  …  38-57  58-77  78-97  98-117  118-137  138-157  158-177  178-180
