Mac OSX v3 prototype available now
 1  …  42-61  62-81  82-101  102-121  122-141  …  162-180
4737.82 In reply to 4737.81
>It looks like I will probably put it here: ~/Library/Application Support/Moi/moi.ini
Great.
>.. (which is stored in the path you show above there contained inside the .app itself currently)
I just discovered that the "open package" procedure I described is not needed to edit the ini file. You provide an easy way to edit the ini file from inside MoIs options which works well. Especially because I'm forced to close MoI before I do this. The ini file opens in Windows Notepad program supplied by Wine.
EDITED: 25 Nov 2011 by MARTIN3D
Size: 65.8 KB, Downloaded: 79 times, Dimensions: 714x541px
4737.83 In reply to 4737.76
Hi Paul, so I think a 2.5 OSX-specific release will make sense.
The way that will work is that I will take the current v3 beta and polish it up to get it into a release-ready state (which it's actually not too far off from which is why this new plan is feasible in the first place), and then peel that off as a 2.5 OSX version which will be available for purchase as a regular non-expiring release version, which will be the same price as the current v2 version which is $295 USD.
The 2.5 OSX version will be available for free to existing v2 owners and it will provide an entry point to purchase for new users who have been waiting until there is an OSX version before getting into MoI.
That should make it possible for me to have an OSX version in a much sooner time frame than my original plan of waiting until the full v3 development cycle to be complete.
It's still difficult for me to give an exact timetable but something like end of January as a release target seems like a good guess. Usually my guesses are pretty wrong though...
I will put together some kind of publicly available pre-release trial version at some point before that, maybe something like 1 more month from now for that part.
4737.84 In reply to 4737.82
Hi Martin,
> by Wine.
Yup, but although that works ok, it's kind of weird and I think it should probably be pretty easy for me to get it to open up with the OSX TextEdit.app instead of Wine Notepad.
I'll see about making that tune up along with the update to have the moi.ini file located in ~/Library/Application Support/Moi .
4737.85
Great move!! Last night i told a friend MoI was making its way into the mac and today he told me he bought it and another friend is really close to buy it too!! I think MoI will be very very popular between mac users cause there is no good solution for Nurbs modeling in this platform. btw I'm very exited for this release too!!
4737.86 In reply to 4737.85
The mood is changing around my house too!!!
4737.87 In reply to 4737.86
You should really get some sleep Burr you look terrible........and that hat doesn't suit you at all ;)
4737.88 In reply to 4737.87
Not the first time I've been referred to as "StoneFace!" :o RAPANUI!
4737.89 In reply to 4737.84
Fine, if there are no text encoding problems between the two different operation systems.
Speaking of dressing up MoI.app :) I found all icons in the ui/icon folder except for those that seem to be supplied by the Windows system like the attached ones.
I don't know if it's worth the effort but if I want to do it is there a possibility to exchange those myself?
4737.90 In reply to 4737.89
Hi Martin,
> attached ones.
Those particular ones are actually built into the resources section of the moi_lib.dll file, just because the licensing terms of the icon library they come from said they needed to be distributed that way.
You can override them by placing in files in the /ui/icons folder with the following names:
Those should usually be 64x64 PNG images with alpha channel.
If the icon loader finds files that you have created with those names inside the /ui/icons folder it will use them instead of the resource-embedded image for those ones.
4737.91 In reply to 4737.90
thats great, thanks. Following your straightforward naming rules I suppose the names of the following icons
are
Correct?
I like the icons you made but not the ones Bill Gates designed ;-)
4737.92
One more question:
Can MoI be closed by a script?
I would like to assign the standard Apple shortcut cmd+Q for closing an app (For the time beeing it would be Alt+Q).
I use that shortcut all the time.
4737.93 In reply to 4737.91
Hi Martin,
> Correct?
Yup, those look correct. There are also 3 more like that on the Edit palette in the side pane:
> Gates designed ;-)
Those ones are not actually stock MS icons, they're part of an icon set from a professional icon designer. I guess they're getting a little bit out of style though, I may look into replacing them at some point.
4737.94 In reply to 4737.92
Hi Martin,
Put the following script in for the command part of the shortcut key for that:
script: /* Exit MoI */ moi.ui.mainWindow.close();
4737.95 In reply to 4737.94
Michael great job as usual, thanks for the OSX version. I am currently testing it on an iMac 24" OSX 10.7.2 2.8 GHz. Core 2Duo/ATI Radeon HD 2600 Pro 256 MB/4Gigs ram. It runs great so far with a few exceptions the app will not hold any customized settings like full screen on launch, UI size, grid colors, show axis icon it reverts back to the default settings on start up. I normally run Moi on a 2008 macbook unibody via Bootcamp and Win 7. I look forward to testing it on the Macbook when I get back home. I will report back. I have attached some test images. The flow worked like a charm, the array started to slow things up a bit but I suppose that is to be expected.
4737.96 In reply to 4737.95
Hi phlatt5th, thanks for testing it!
Re: settings not sticking - I think that depends on which method you use for exiting - if you exit by clicking the red close button on the upper left area of the window it should have settings saved on exit, but not if you do it doing quit by the dock icon instead. I'd like to fix that, but for the moment use the upper-left control for your settings to persist.
4737.97 In reply to 4737.96
The UI settings now hold when I exit using the upper left button. Thanks for the tip. A few more questions, I would like to use some of the scripts on the resource page is that possible? especially the spacebar fullscreen under cursor one (PS I am so used to it I click on it looking for the same reaction in other 3D apps LOL) and where is the commands folder kept? How would I get it to remember the full screen on launch?
4737.98 In reply to 4737.97
Hi phlatt5th,
Yeah pretty much all the scripts should work exactly the same in the OSX version. The only one that probably won't work is the import point file one since it uses a Windows system component for reading a text file in. At some point I'll provide some text file services for scripts so that can be made to work as well.
But other than that one script I think every other one ought to work, please let me know if you find any that don't.
It should work - please let me know if it doesn't.
It doesn't seem like the window size will stick right now, that's probably the only setting that doesn't. I'll look into that.
4737.99 In reply to 4737.98
>It doesn't seem like the window size will stick right now, that's probably the only setting that doesn't. I'll >look into that.
is there a window menu on the menu bar when running moi?
if so, is there an a window->zoom menu choice?
if so :) , try clicking the green button at the top left of the moi window (maximize) then go window->zoom..
you should be able to resize the window to your liking now and it will be remembered across sessions.
[lots of ifs in this :) ..but this does work in certain other osx apps that can't remember their size]
4737.100 In reply to 4737.94
Thank you Michael.
Alt+Q script: /* Exit MoI */ moi.ui.mainWindow.close();
works fine and closing the app by cmd-Q also remembers the settings.
It takes about five seconds until Moi actually closes by the way. But I guess thats because X11 is also closing in the background.
I'm glad you provided a straightforward way to customize the MoI Icons.
EDITED: 27 Nov 2011 by MARTIN3D
Size: 163.2 KB, Downloaded: 107 times, Dimensions: 1153x959px
4737.101
Hello Michael
I really want to test this version, but I have the license version 1.
I did not have version 2, because I have no license "windows" on my Mac.
But now a Mac version, I dream !!!!!! I buy as soon as possible!
Thank you in advance
Vincent
De : Objet: Date : À: Répondreà:
Michael Gibson <moi@moi3d.com>
MomentofInspiration1.0-OrderInformation
26 mai 2008 14:10:21 HAEC sajous.v@............... MichaelGibson<moi@moi3d.com>
Dear Vincent, Thank you for your purchase of: (1) - Moment of Inspiration 1.0 - Full Version
Your download link:
http://www.plimus.com/..............................................
Your license key: VER1-...............................................
Show messages:  1  …  22-41  42-61  62-81  82-101  102-121  122-141  142-161  162-180
