Mac OSX v3 prototype available now
 1-12  13-32  33-52  53-72  73-92  93-112  …  173-180
4737.53 In reply to 4737.52
Hi Martin - so the MoI shortcut key editor thing is rather primitive and you actually need to type in the label of the key you want to use there, not just press the key itself.
So for example to assign Backspace, type in the actual text:   Backspace   in that field and then that should work. Just hitting backspace will actually just edit the text in that field and not assign that key.
I want to overhaul this in the future to work more like you were expecting it to, it's just been hard to dedicate much time to it yet since it's not something that you have to deal with usually all that much.
> ctrl-C and ctrl-V do nothing. This is bad since there's no
> menu alternative.
Well, there is on the Edit palette on the side pane, but it's not a shortcut problem, the actual functions for copy and paste don't seem to be working properly and I'll be looking into fixing them.
To get the Cmd key working instead of Ctrl you can right now try editing the shortcuts and putting in Alt in place of Ctrl and then it seems like they will work with the Cmd key actually.
That will be another area that I'll need to tune up for the OSX version, to recognize Cmd as a shortcut key and to have the defaults use Cmd+c for example instead of Ctrl.
Please let me know if you run into any other problems than these.
4737.54
Thanks. Michael.
Working great - except the issues mention above - in a 2009 iMac 27", 2,8 Ghz, 4GB, ATI HD 4850 512 MB, Mac OS Lion 10.7.2.
Moi was the main reason to switch to Win PC: Moi is an Amazing application!
Cheers, Carlos
4737.55 In reply to 4737.48
>There are a few variations of Arial, including stuff like Arial.ttf, Arial Black, Arial bold, etc... if you can get those back into your /Library/Fonts folder that should hopefully fix up that problem.
Thanks a lot. The Arial family was the first font I tried yesterday but I made the mistake to install all fonts into my Username/Library/Fonts folder. I just moved all Arials to /Library/Fonts, restarted MoI and enjoyed the result.
4737.56 In reply to 4737.53
Works fine, thanks!
Not needed if there's a shortcut section for OS X users in a future help file.
>try putting in Alt in place of Ctrl
Works fine. Don't waste your time in fixing that just mention it in a future help file.
We'll do.
So far MoI works very well, it's fast and responsive and best of all I have no need to fire up VMWare and look at Windows 7 (Sorry I can't stand it).
The resizing display stuff is also no problem for me.
Also the Windows file dialog is totally usable. With it's File Save Undo .. Icons at the bottom MoI clearly isn't expected to work exactly as an native OS X app anyway and that's fine. I can do what I need in MoI now without any virtualisation software. I couldn't be more satisfied just as it is now.
Also allowing one licence for both operating systems is a very generous policy by you. I'll probably (hopefully) don't need Windows for the rest of my live but others use both. I wished more companies would act like you.
I'm looking forward to upgrade to the OS X version MoI.
4737.57 In reply to 4737.55
Hi Martin,
Actually what you did there was supposed to work but it looks like I've got a bug in the thing that was supposed to also look in that alternate Username/Library/Fonts folder.
So I'm glad you mentioned that part so that I can fix that up too.
For this first version the fonts will need to go into /Library/Fonts for the moment to be seen by MoI.
4737.58 In reply to 4737.56
Hi Martin,
Well, I really do need to overhaul it at some point because a lot of people expect for it to work in the more usual way of doing the keystroke that you want to set, and a lot of people won't read help file stuff.
This is great news that it's fast and responsive - that seems to be one area that this particular porting mechanism is good at doing.
Yeah - it's somewhat that way actually on the Windows side as well - that it doesn't particularly follow typical Windows UI conventions there either. That's kind of an advantage at this point though since it doesn't look overall as weird as a regular Windows program would running under OS X. That is until that file open dialog comes up which really does stick out like a sore thumb. I definitely want to try and get the native dialog working, I don't think it will be too much work.
Anyway, I'm really glad that it's working well for you so far!
4737.59 In reply to 4737.1
thank you thank you thank you!! been waiting/hoping for this a long time! so, as a student, if i buy the EDU version of v2 now will i get to use the beta? and what's the upgrade path to v3 when 1.0 comes out? this is really good news and it's looking good too, great job!
4737.60
WOWOWOWOWWOWOW......WOWOWWO
thaNX!!!!!Thanxxxxxxxx.....Michael you rock!!!!!
4737.61 In reply to 4737.36
Here's the screenshot on my black mac (running lion).
4737.62 In reply to 4737.59
Hi weipai,
Yes, any v2 license including an EDU license has access to the v3 beta releases.
You'll need to purchase an upgrade license to the v3 version when it's all finished up and the beta period is complete. There should be an edu discount upgrade version available, it will probably cost the same as the v1 to v2 upgrade which was $50 for educational, $100 for regular commercial.
It will still be quite a while before the final v3 is ready, I expect the beta period to probably run through until late next year.
4737.63 In reply to 4737.61
Hi Luis,
Thanks for posting that - I did see something similar to that while developing it, and I think it has to do with a particular OpenGL function not being available.
I'm not sure if it's really not available or if there is some bug where it just thinks that the function is not available when it actually is.
I will be looking into getting an OSX laptop with the Intel graphics chipset so I can do some testing with it and see if I can solve this problem or not.
4737.64 In reply to 4737.63
Is there anything I can try looking into (e.g. video settings, moi config, etc.) and modifying so i can help you with the testing?
4737.65 In reply to 4737.64
Hi Luis,
> testing?
I don't think there's anything like that you could do with the current version - I'll probably need to do some debugging here with it and I'll need to go back and forth between making changes in code and testing it frequently so I'll pretty much need to have a machine right here to test with.
I'll look into it more next week and see what I can figure out.
4737.66
This is what i was waiting to buy MoI for a long time! Just had to buy it right now that i heard of it!
Thanks Michael! I'll give it a try and tell you how it runs.
Specs:
IMac 27" 2010
core i5 2.8
16gb ram
ATI Radeon HD 5750
I'll be happy to post results once i get my order approved!
4737.67 In reply to 4737.66
Wonderful.. perfect timing.. Now I can get rid of bootcamp!
4737.68
Not sure I understand what it takes to try out the beta. Do I need to get version 2 for a Platform I don't use to try out a beta version on a mac and then pay again for the upgrade to version 3 when it comes out. Not sure but something doesn't sound right there or maybe I am just missing the point totally. Perhaps it a long beta and it probably makes a little more sense then but then again I have been testing out Rhino on the mac for the last two years without buying the windows version of it. Will end up buying it when it is finally released.
I have been watching this software for a few years now and have been hoping that a mac version would come out and so have a lot of other mac users. I hoping eventually there is a stronger, wider beta release. It can only mean more eventual customers.
4737.69 In reply to 4737.68
Hi silba - I'd advise you to wait until v3 is finished. When it is finished then I will be making a trial version for it and that trial version will be available for anybody to download without any purchase to test with.
Beta versions are different than trials - my policy for beta versions so far has been that it is available for previous owners to download during the beta period. That's because otherwise if every single beta release was just totally open for anyone to download that would mean that there would always be a free version available to use.
That there happens to be an OSX version that you are unable to try out without already owning a license is just a temporary situation - once the final v3 is released then there will be a trial version available for people to test with before purchasing.
So if you don't want to purchase any license you will still be able to try it, you'll just need to wait until it is out of beta. That will probably be sometime late next year.
4737.70 In reply to 4737.68
Hi silba, also re:
The Rhino mac version is a pretty different situation than the MoI one.
Basically the Rhino Windows version generally follows 1990s era standard Windows-PC interface conventions. Or in some areas like with the command-line handling maybe even more like 1980s era. That would end up being pretty weird if it was just brought over directly to the Mac. So instead they basically started over and have been trying different UI concepts for their Mac version and also started out at a much more primitive level initially. They still have quite a ways to go I guess even now.
When doing something from scratch like that it does make a lot of sense to have a wide and totally open beta test since you will need to get a whole lot of feedback to guide something that is in the process of growing and not really close to fully formed.
The MoI Mac beta is totally unlike that - instead of being in a "start from zero" state, it has the full functionality and interface of the regular Win MoI.
Having the same UI on both Win and Mac is much more feasible for MoI than it would have been for Rhino because the Win MoI version did not particularly follow many standard Windows conventions and even had a semi-mac-like more modern design feel to it. So that exact same UI with possibly a few small tweaks here and there but largely intact is not so weird on the Mac, or possibly you might say it's equally as weird on both Windows and the Mac I suppose.
At any rate, it's a much different situation and the MoI OSX version basically pops into existence much more fully formed and equal in functionality to the PC version and not needing such a long incubation period as a "start from scratch" type approach requires.
4737.71 In reply to 4737.70
Hi Michael!
As the OSX-version is generating quite a buzz in the 3D domain, couldn't you provide a non-save-beta for "unilluminated" Apple-ians to sneak a peek on MOIs toolkit?
Best of wishes,
Marco
4737.72
Just to chime in here. As a long time C4D users who have battled with Solidthinking for most nurbs modeling we've been looking for a way to dump this overpriced and unstable beast of a program. We have not upgraded from Solidthinking Vantage due to sky high prices and the fact the modeler component is all we need. So we are still on the look out for a dedicated nurbs modeler.
That was going to be Rhino OSX, but now....
We've heard a great number of people recommend MoI and would very much like to try it out. Going by the current $295 price point (should testing prove as satisfactory) we would have no reservation in making an immediate purchase of the OSX version of this app.
It would be very much appreciated if we could test with a view to purchase.
Show messages:  1-12  13-32  33-52  53-72  73-92  93-112  113-132  …  173-180
