Mac OSX v3 prototype available now
 1-8  9-28  29-48  49-68  69-88  89-108  …  169-180
4737.49 In reply to 4737.47
Hi Martin,
> I just installed MoI on my *11-inch* MacBook Air bought in
> January 2011 (with Snow Leopard) and it's totally useable.
That's good to hear - so far the problems seem to be related to systems using the Intel video chipset for the graphics.
4737.50
Michael Thank you for taking the time to make this happen. I sincerely appreciate Running MoI on my Mac.
4737.51 In reply to 4737.50
No problem, I really hope it will be useful!
Please let me know if you find anything that does not work right.
4737.52 In reply to 4737.47
Regarding shortcuts:
ctrl-X, ctrl-S, ctrl-O, ctrl-N, F1 for example work right out of the box.
I was not able to assign the cmd key instead of the ctrl key. The Key field remains blank when I tried to fill in cmd-X for example.
ctrl-C and ctrl-V do nothing. This is bad since there's no menu alternative.
Trying to assign the Backspace key instead of the Delete key also leaves the Key field blank. But ctrl-X works fine as an alternative.
4737.53 In reply to 4737.52
Hi Martin - so the MoI shortcut key editor thing is rather primitive and you actually need to type in the label of the key you want to use there, not just press the key itself.
So for example to assign Backspace, type in the actual text:   Backspace   in that field and then that should work. Just hitting backspace will actually just edit the text in that field and not assign that key.
I want to overhaul this in the future to work more like you were expecting it to, it's just been hard to dedicate much time to it yet since it's not something that you have to deal with usually all that much.
> menu alternative.
Well, there is on the Edit palette on the side pane, but it's not a shortcut problem, the actual functions for copy and paste don't seem to be working properly and I'll be looking into fixing them.
To get the Cmd key working instead of Ctrl you can right now try editing the shortcuts and putting in Alt in place of Ctrl and then it seems like they will work with the Cmd key actually.
That will be another area that I'll need to tune up for the OSX version, to recognize Cmd as a shortcut key and to have the defaults use Cmd+c for example instead of Ctrl.
Please let me know if you run into any other problems than these.
4737.54
Thanks. Michael.
Working great - except the issues mention above - in a 2009 iMac 27", 2,8 Ghz, 4GB, ATI HD 4850 512 MB, Mac OS Lion 10.7.2.
Moi was the main reason to switch to Win PC: Moi is an Amazing application!
Cheers, Carlos
4737.55 In reply to 4737.48
>There are a few variations of Arial, including stuff like Arial.ttf, Arial Black, Arial bold, etc... if you can get those back into your /Library/Fonts folder that should hopefully fix up that problem.
Thanks a lot. The Arial family was the first font I tried yesterday but I made the mistake to install all fonts into my Username/Library/Fonts folder. I just moved all Arials to /Library/Fonts, restarted MoI and enjoyed the result.
4737.56 In reply to 4737.53
Works fine, thanks!
Not needed if there's a shortcut section for OS X users in a future help file.
>try putting in Alt in place of Ctrl
Works fine. Don't waste your time in fixing that just mention it in a future help file.
We'll do.
So far MoI works very well, it's fast and responsive and best of all I have no need to fire up VMWare and look at Windows 7 (Sorry I can't stand it).
The resizing display stuff is also no problem for me.
Also the Windows file dialog is totally usable. With it's File Save Undo .. Icons at the bottom MoI clearly isn't expected to work exactly as an native OS X app anyway and that's fine. I can do what I need in MoI now without any virtualisation software. I couldn't be more satisfied just as it is now.
Also allowing one licence for both operating systems is a very generous policy by you. I'll probably (hopefully) don't need Windows for the rest of my live but others use both. I wished more companies would act like you.
I'm looking forward to upgrade to the OS X version MoI.
4737.57 In reply to 4737.55
Hi Martin,
Actually what you did there was supposed to work but it looks like I've got a bug in the thing that was supposed to also look in that alternate Username/Library/Fonts folder.
So I'm glad you mentioned that part so that I can fix that up too.
For this first version the fonts will need to go into /Library/Fonts for the moment to be seen by MoI.
4737.58 In reply to 4737.56
Hi Martin,
Well, I really do need to overhaul it at some point because a lot of people expect for it to work in the more usual way of doing the keystroke that you want to set, and a lot of people won't read help file stuff.
This is great news that it's fast and responsive - that seems to be one area that this particular porting mechanism is good at doing.
Yeah - it's somewhat that way actually on the Windows side as well - that it doesn't particularly follow typical Windows UI conventions there either. That's kind of an advantage at this point though since it doesn't look overall as weird as a regular Windows program would running under OS X. That is until that file open dialog comes up which really does stick out like a sore thumb. I definitely want to try and get the native dialog working, I don't think it will be too much work.
Anyway, I'm really glad that it's working well for you so far!
4737.59 In reply to 4737.1
thank you thank you thank you!! been waiting/hoping for this a long time! so, as a student, if i buy the EDU version of v2 now will i get to use the beta? and what's the upgrade path to v3 when 1.0 comes out? this is really good news and it's looking good too, great job!
4737.60
WOWOWOWOWWOWOW......WOWOWWO
thaNX!!!!!Thanxxxxxxxx.....Michael you rock!!!!!
4737.61 In reply to 4737.36
Here's the screenshot on my black mac (running lion).
4737.62 In reply to 4737.59
Hi weipai,
Yes, any v2 license including an EDU license has access to the v3 beta releases.
You'll need to purchase an upgrade license to the v3 version when it's all finished up and the beta period is complete. There should be an edu discount upgrade version available, it will probably cost the same as the v1 to v2 upgrade which was $50 for educational, $100 for regular commercial.
It will still be quite a while before the final v3 is ready, I expect the beta period to probably run through until late next year.
4737.63 In reply to 4737.61
Hi Luis,
Thanks for posting that - I did see something similar to that while developing it, and I think it has to do with a particular OpenGL function not being available.
I'm not sure if it's really not available or if there is some bug where it just thinks that the function is not available when it actually is.
I will be looking into getting an OSX laptop with the Intel graphics chipset so I can do some testing with it and see if I can solve this problem or not.
4737.64 In reply to 4737.63
Is there anything I can try looking into (e.g. video settings, moi config, etc.) and modifying so i can help you with the testing?
4737.65 In reply to 4737.64
Hi Luis,
> testing?
I don't think there's anything like that you could do with the current version - I'll probably need to do some debugging here with it and I'll need to go back and forth between making changes in code and testing it frequently so I'll pretty much need to have a machine right here to test with.
I'll look into it more next week and see what I can figure out.
4737.66
This is what i was waiting to buy MoI for a long time! Just had to buy it right now that i heard of it!
Thanks Michael! I'll give it a try and tell you how it runs.
Specs:
IMac 27" 2010
core i5 2.8
16gb ram
ATI Radeon HD 5750
I'll be happy to post results once i get my order approved!
4737.67 In reply to 4737.66
Wonderful.. perfect timing.. Now I can get rid of bootcamp!
4737.68
Not sure I understand what it takes to try out the beta. Do I need to get version 2 for a Platform I don't use to try out a beta version on a mac and then pay again for the upgrade to version 3 when it comes out. Not sure but something doesn't sound right there or maybe I am just missing the point totally. Perhaps it a long beta and it probably makes a little more sense then but then again I have been testing out Rhino on the mac for the last two years without buying the windows version of it. Will end up buying it when it is finally released.
I have been watching this software for a few years now and have been hoping that a mac version would come out and so have a lot of other mac users. I hoping eventually there is a stronger, wider beta release. It can only mean more eventual customers.
Show messages:  1-8  9-28  29-48  49-68  69-88  89-108  109-128  …  169-180
