Mac OSX v3 prototype available now
 1-9  10-29  30-49  50-69  70-89  …  170-180
4737.30 In reply to 4737.6
Hi Ralf,
> (This iMac was bought Jun. 2006, one of the first iMac`s, a grandpa :-)
> Download & Installation = without problems
> Licensing = without problems
> First impression = Great!
Thanks for testing it on this older iMac, that's great to know that it is working well there, that's definitely a good sign! :)
4737.31 In reply to 4737.8
Hi Martin,
> I use OS X 10.6.8 Snow Leopard and my first impression after
> playing a few minutes with the prototype is very positive.
This is great news, thanks for testing it!
> C: is the windows disk and Z: is my Mac disk which I can
> browse fine with the windows file interface.
I'm hoping to make this part only temporary though, I will be trying to use the native file dialog and native file paths pretty soon.
> I seem to miss a certain font though as you can see in the
> screen shots. The font for the keyboard shortcuts and the font
> for the lables "3D" "Top" "Front" "Right" is missing.
When you go to draw a line or something that uses snaps, are the little labels that attach to snap points that say what it is like "End", etc.. also missing?
Does your Mac have English as its main OS language setting, or something else?
4737.32 In reply to 4737.9
Hi Jeff,
> would love to beta test this but, you know, not too many
> mac users out there would actually have a v2 license.
I've actually heard from quite a few MoI users who currently run MoI v2 on a Mac either with Parallels/VMWare or Boot Camp.
So I guess that those users will be at the front lines of testing the beta versions.
I think that there will be enough people using it to get it tested well until the v3 final version is out though.
4737.33 In reply to 4737.10
Hi Chyman,
> Hi Michael, this is wonderful news! Especially ycarry's tests
> with Snow Leopard on MacBook, which is the combination I
> have, sound very promising.
Well, it sounds like the Intel chipset is the main thing that does not work currently unfortunately.
However, I don't think that MoI actually needs to do anything that the Intel chipset cannot actually do, so there is still some hope that it might be able to work.
But in general the Intel chipset is much lower powered in 3D performance than stuff from either ATI or nVidia, so for 3D specific use it is usually better to have either ATI or nVidia graphics.
> As Jeff mentions, do I have to purchase a v2 license first in
> order to make a test? You not happen to have a trial of this..
> I guess not.. well if the GFX is the same I am ready to jump!
Yeah this is a beta version, not a trial version - I will eventually have a trial version ready but not until the v3 beta period is over and the final release is out, that's been the regular beta process for a while now.
4737.34
This sounds great for the Mac users!
Excuse my Mac ignorance, but will MoI now run on let's say an iPad?
Michael T.
4737.35 In reply to 4737.34
Hi Michael T,
No, the iPad is pretty much a separate kind of thing than a Mac - it has a totally different CPU in it. The new MoI version does not run on an iPad, only on a regular Mac.
You can set up a remote desktop app for the ipad so you can control your main computer's screen from it though.
Some recent discussion on it here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4644.1
4737.36 In reply to 4737.18
Hi Luis,
> Tried it on an my black macbook with Lion (OSX 10.7.2) but
> the views don't work. only get a big pixelated black ellipses
> on all of them. doesnt matter if I switch to single view
> either. :(
> any suggestions?
This seems to so far be the main case where there has been a problem, and it's probably something related to the Intel integrated graphics which that macbook model uses for its 3D graphics display.
Could you try to post a screenshot of your screen so I can see if there is only some particular portion of the display that is not working right? Seeing the result may help to give me some clues on what area to look at.
I don't think that MoI actually needs to use anything that the Intel chipset is not able to do, so there is some possibility that things could be tweaked so that they work there, but it's also a matter of whether Apple's driver for that video card is good enough as well or if that driver is buggy.
4737.37 In reply to 4737.22
Hi ycarry,
> By the way how change options?
> i.e. some keys not works... and all are with Ctrl not Cmd
For the Delete command put in Backspace in the left-hand column and then you should be able to delete stuff.
In place of Ctrl try Alt instead and then see if that works with the actual Cmd key.
It looks like Copy/Paste of objects may not be working right though.
4737.38 In reply to 4737.24
Hi Stever,
> running it on my iMac 27in Snow Leopard.
> Overall looking great. Need more time to play
Great, thanks for testing it!
> Just to let you know having issues with copy and paste not
> working via ctr C and ctr V and via menu.
Yeah that seems to be busted, I'll be examining that.
> Unusual using the CTR rather than CMD key on Mac. Having
> Issues assigning keys using the Cmd key
Try putting in the MoI options as Alt - does that then work when you actually use the Cmd key? Other than for copy/paste which is busted somewhere else.
Also if you don't have a delete key on your keyboard put in Backspace in the left-hand column for the Delete command shortcut.
4737.39 In reply to 4737.32
sounds good.. i'll check back here occasionally to see how things are progressing.
thanks
4737.40
Working great on my little Mac Mini (Snow Leopard v. 10.6.8). Now I know what I'm grateful for this Thanksgiving: Thanks for bringing MoI over to the Mac, Michael. I might have an upcoming job that will require the on-site usage of a Macbook and I can just about guarantee I won't be allowed to use Windows via Bootcamp if I do (nor do I want to spring for the additional cost of the OS). You couldn't have picked a better time to release this.
EDITED: 23 Nov 2011 by SURLYBIRD
Size: 885.5 KB, Downloaded: 131 times, Dimensions: 1280x1024px
4737.41 In reply to 4737.33
Thank you for your comments, Michael. I will closely watch the testing progress and look forward to a Demo version at the end of beta phase.
I am thinking to update my Mac hardware at some point in future and all the hints and tests here are very helpful to make the right decision.
Still hoping though that you may get the Intel gfx to work...
Thanks again for your dedication,
Chyman
4737.42 In reply to 4737.41
I have not purchased yet because I was waiting for the Mac version. Any chance of getting a trial of the Mac version at this stage?
4737.43 In reply to 4737.42
Hi Jeff, right now it's at the "beta" stage - I do expect to have a trial version in the future, but I make trial versions for fully released programs, not for each beta release.
So there will be a trial for it eventually when the beta period is finished.
4737.44
Thank you so much Michael! Now I don't need my pc anymore. :)
Installation went well, but the copy and/paste command didn't work.
4737.45 In reply to 4737.44
Hi wzhang, I'm glad it will be useful!
Yes it looks like Copy/Paste is one thing that is broken - I will be looking into fixing that up.
Please let me know if you find any other functions that don't work right either.
4737.46 In reply to 4737.31
I use an English system. Yes, the snap point labels are also missing.
I guess my problem is that I deleted a lot of OS X fonts from which I thought that I will never need them. Fonts like Arial, Trebuchet, MS Sans Serif and so on. Yesterday I used Pacifist to extract missing fonts from my Snow Leopard Install DVD and installed a lot of them. But unfortunately I still didn't find the right one. I think when you tell me the name of the font used for the labels and the Shortcut window I'll be able to solve the problem.
4737.47 In reply to 4737.14
>I'm curious to see how(if) it would run on a 13" mbp or air..
I just installed MoI on my *11-inch* MacBook Air bought in January 2011 (with Snow Leopard) and it's totally useable.
Size: 476 KB, Downloaded: 95 times, Dimensions: 1366x768px
Size: 123 KB, Downloaded: 90 times, Dimensions: 548x438px
4737.48 In reply to 4737.46
Hi Martin,
Yeah that's probably the problem then - right now it's set up to use Arial and I had just assumed that it would be present since it's part of the stock OSX install.
There are a few variations of Arial, including stuff like Arial.ttf, Arial Black, Arial bold, etc... if you can get those back into your /Library/Fonts folder that should hopefully fix up that problem.
It's also possible to change the font that MoI uses for the UI - that's a setting in the moi.ini file, let me know if you want to change that and I will describe how to do that. Some fonts seem to cause problems though.
4737.49 In reply to 4737.47
Hi Martin,
That's good to hear - so far the problems seem to be related to systems using the Intel video chipset for the graphics.
Show messages:  1-9  10-29  30-49  50-69  70-89  90-109  …  170-180
