Mac OSX v3 prototype available now
 1-9  …  110-129  130-149  150-169  170-180
4737.150
Are you kidding me? This is amazing! Been using it a few day and seems to work perfectly. Thanks for the great work.
-Shane
4737.151 In reply to 4737.150
You're welcome Shane, I'm glad that it's working well for you!
I've been working on some updates to it and making some progress, I've nearly got the native OSX file open and save dialogs working properly and then I have just a few other things to fix up before releasing a new updated OSX beta.
4737.152 In reply to 4737.151
Thanks Michael, that is great news.
Is there a way to be notified of the new build or should I just check back here from time to time?
It really feels like a native app other than the OS X dialogs that you mentioned and a few other very minor things like the Windows hot keys for copy & paste and command +Q not working.
Very excited you were able to make this happen!
-Shane
4737.153 In reply to 4737.152
Hi Shane,
I don't really have any method set up to get an e-mail notification for stuff like that, so just checking back here every once in a while is the best way to find out about it.
Yup, copy & paste using the Cmd key and Cmd+Q are on my list to address as well.
4737.154
I successfully finished the first test project :)
Nothing to report besides what has already been said...I´m looking forward for the the next Beta with native OSX file dialogs.
iMac
AMD Radeon HD 6970M 1024 MB
MoIchael you Rock :)
4737.155 In reply to 4737.153
Michael,
Thanks a bunch for providing a Mac version, I am long time user and since I recently switched to Macs (MacAIr, IMac, Mac Pro), I have really missed using MOI3D. All my older files have loaded and behaved well so far.
Thanks again.
Paul
4737.156
Been away... came back and a mac version! Tested and works perfectly :) 10.6.8 2.8 Core i7 Macbook Pro.
Thanks Michael :)
4737.157
Michael,
I have been using the Mac OSX version a bit more and I have run into some stability problems. My file size is 243.3 MB, and I have been getting frequent "insufficient memory" warnings when exporting, followed by objects missing in the files. I have been able to recover most of my work in the bak.3dm files that show up afterwards but it is getting a bit frustrating.
I am in the process of breaking this file into several smaller files to see if this helps. Just thought I would report the situation.
This is on a one year old MacPro 2x2.4 GHZ Quad core machine with 12 GB ram. Cheers
4737.158 In reply to 4737.157
Hi Paul, MoI is a 32-bit application and so it's only able to use about 4GB or so of your total memory.
When you get that insufficient memory warning when exporting, that means that there is not enough room in that 4GB to hold all the data that you have currently asked to generate.
There are a few things you can do to solve this.
One is that you already mentioned - break it down into some smaller files instead of one huge monster file.
Another one is that if you're only running out of memory when generating polygon mesh data to go into a polygon mesh format, you can do just the export in smaller chunks at a time instead of all at once. To do that select some set of objects and then use the File > Export command instead of File > Save As. The export command only writes the selected objects to the file instead of everything and generating meshes for only some subset of objects instead of all at once should also reduce peak memory load.
Another thing that can help reduce memory load with more complex models is to adjust a setting to make the display mesh rougher. By default MoI generates a pretty high density display mesh which makes objects look nicer but it can also consume quite a bit of memory when you have a whole lot of model data. See this previous post for the settings to adjust to make the display mesh density rougher:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4558.4
4737.159 In reply to 4737.158
Michael,
Any plans to transition over to 64 bit?
4737.160 In reply to 4737.159
Hi Seb,
No, not anytime soon anyway. There is a lot of work involved to make that happen, including moving to a new compiler and updating various support libraries and stuff like that. The amount of work involved is substantial enough that I do not really expect to be able to undertake it anytime too soon.
4737.161 In reply to 4737.158
Michael,
Thanks for the tips. I was eventually able to get everything exported. In fact the geometry that was giving me the most difficulty was an imported step file, that had a very small spring inside one of the larger structures. I hid these, and it was fine.
I have attached a render I did in modo, so you have an idea of the complexity I was dealing with. This is a mock up of physics experiment I plan to build, I use MOI to quickly validate design and make sure everything will fit, how many pieces I need, etc.
I love your software and you are without a doubt brilliant, thanks again for existing!
4737.162 In reply to 4737.161
Hi Paul, wow that is a lot of details, and what an amazing looking experiment! It is so cool that you're able to pre visualize it like this!
4737.163
Amazing shape indeed!
Marc
4737.164 In reply to 4737.161
Awesome Paul! and a fantastic rendering!
Michael T.
Technologic!
4737.166
Awesome Paul. That looks like some of the stuff we do in SolidWorks with LINACS where I work - except for the rendering, which we can't spend a lot of time on.
Michael,
Thanks a lot for bringing MoI to the Mac platform. I still have a Windows machine but I've been migrating to the Mac platform in the last year. The beta version is working well on the 2011 iMac I got about 6 months ago.
Keep up the good work!
Regards,
fleetfoot
EDITED: 26 Jan 2012 by FLEETFOOT
4737.167 In reply to 4737.166
You're welcome fleetfoot, I'm glad that the Mac version has been working well for you so far!
4737.168 In reply to 4737.167
How long now until you release a Mac Moi Trial for us Michael?
4737.169
Just to say it's working really well here. OSX 10.6.8 Quad Core Intel Xeon. Thanks a lot, Michael. Wasn't expecting to see a Mac version anytime soon.
Rich
www.loopcorp.com
Show messages:  1-9  …  90-109  110-129  130-149  150-169  170-180
