Mac OSX v3 prototype available now
 1-17  …  98-117  118-137  138-157  158-177  178-180
4737.138 In reply to 4737.137
That's great news Luis!
It turns out that it was kind of accidental that it was actually doing offscreen rendering at all, I think I will have something to send you in a bit here which tweaks a couple of other things.
But it does look like it's going to be possible to get it to work there after all.
4737.139 In reply to 4737.137
I'll also tune it up so that if your card doesn't support fbo it will turn that offscreen rendering mode to "backbuffer" by default.
But basically it was trying to use fbos because it thought it was rendering at one size and then going to later on display the final result in a different sized window than the rendering when that's not really what happens. Now that I've got that fixed up it doesn't worry about trying to use fbos or offscreen rendering at all which should simplify things.
4737.140 In reply to 4737.139
I cannot send you a pm. The system is blocking it with an opted out msg.
--Luis
4737.141 In reply to 4737.140
Hi Luis,
Seems that my PM space was filled up, I've freed up some room can you please try again?
4737.142 In reply to 4737.141
no love still. pm not working. could be me. but i've logged out and logged back in a few times...
4737.143 In reply to 4737.142
Hi Luis, can you send me an e-mail at moi@moi3d.com instead?
4737.144 In reply to 4737.116
Just wanted to confirm that besides the window-lags from time to time on resize – It runs smooth as a catweasel. Love it.
The load / save / file dialogs coud be integrated better, but hey – it works .. :D
10.6.8
2.4Ghz 2010 Mac Mini
4737.145 In reply to 4737.144
Hi SW03, thanks for testing it!
Yeah that's probably the single weirdest part right now - I do plan on overhauling these to use the native OSX file dialogs, and I'll also try to tune up the window sizing as well.
Of course in the grand scheme of things it's not so common to resize the window as it is to do stuff like rotate and pan the views, so it's good that the much more heavily used area of the regular screen redraw is working smoothly already.
4737.146
I'm a bit late to the party but, a Mac OS version, Michael?! This is amazing and it will be great for Mac users who did not want to bootcamp, etc. to Moi.
To me, Moi is sort of a professional paradox: with Moi it is possible to do serious work, in less time and have fun doing it.
Congrats, Michael.
Leonard
4737.147 In reply to 4737.146
Thanks Leonard, I'm glad that you've been having fun using MoI!
And yup, I've definitely heard from people who did not want to go through the hassle of setting up bootcamp or Parallels/VMWare (although quite a few people did do that too) so this new version should be helpful since it doesn't need any of that.
4737.148
I attached what i described above with named objects for easier understanding, thanks for your support!
4737.149 In reply to 4737.148
4737.150
Are you kidding me? This is amazing! Been using it a few day and seems to work perfectly. Thanks for the great work.
-Shane
4737.151 In reply to 4737.150
You're welcome Shane, I'm glad that it's working well for you!
I've been working on some updates to it and making some progress, I've nearly got the native OSX file open and save dialogs working properly and then I have just a few other things to fix up before releasing a new updated OSX beta.
4737.152 In reply to 4737.151
Thanks Michael, that is great news.
Is there a way to be notified of the new build or should I just check back here from time to time?
It really feels like a native app other than the OS X dialogs that you mentioned and a few other very minor things like the Windows hot keys for copy & paste and command +Q not working.
Very excited you were able to make this happen!
-Shane
4737.153 In reply to 4737.152
Hi Shane,
I don't really have any method set up to get an e-mail notification for stuff like that, so just checking back here every once in a while is the best way to find out about it.
Yup, copy & paste using the Cmd key and Cmd+Q are on my list to address as well.
4737.154
I successfully finished the first test project :)
Nothing to report besides what has already been said...I´m looking forward for the the next Beta with native OSX file dialogs.
iMac
AMD Radeon HD 6970M 1024 MB
MoIchael you Rock :)
4737.155 In reply to 4737.153
Michael,
Thanks a bunch for providing a Mac version, I am long time user and since I recently switched to Macs (MacAIr, IMac, Mac Pro), I have really missed using MOI3D. All my older files have loaded and behaved well so far.
Thanks again.
Paul
4737.156
Been away... came back and a mac version! Tested and works perfectly :) 10.6.8 2.8 Core i7 Macbook Pro.
Thanks Michael :)
4737.157
Michael,
I have been using the Mac OSX version a bit more and I have run into some stability problems. My file size is 243.3 MB, and I have been getting frequent "insufficient memory" warnings when exporting, followed by objects missing in the files. I have been able to recover most of my work in the bak.3dm files that show up afterwards but it is getting a bit frustrating.
I am in the process of breaking this file into several smaller files to see if this helps. Just thought I would report the situation.
This is on a one year old MacPro 2x2.4 GHZ Quad core machine with 12 GB ram. Cheers
Show messages:  1-17  …  78-97  98-117  118-137  138-157  158-177  178-180
