View Rotation Style
 1  2-21  22-27
4736.22 In reply to 4736.21
Hi Burr, so to switch Mike's script above to the other style labeling, go to the part
of his script where he has: moi.view.rotationStyle = newvrs;
That's the end of the part that actually toggles the setting, everything coming
after that is about pushing in some HTML for the display.
So delete everything after that and instead put in the second half of what I had
above for the other style "bottom corner" label, which would be this (just the
variable used at the very end is different from my previous script):
var sidepane = moi.ui.getUIPanel('moi://ui/SidePane.htm').document; if ( !sidepane.getElementById('meshangval') ) { sidepane.body.insertAdjacentHTML( 'beforeEnd', '<div id="meshangval" style="position:absolute; right:5px; bottom:5px;"></div>' ); } sidepane.getElementById('meshangval').innerText = newvrs;
Let me know if that doesn't work right for you.
4736.23 In reply to 4736.22
I was able to get both the previous toggle scripts to work in Inside browser pane mode now.. Thanks! For the last post you made with the View Angle toggle, the last item was a "newang" in That script (As opposed to newvars).. It adopted to the viewpoint toggle script also!!! (Which used the "newvars" definition.
Can you resume that these new scripts can make?
I am a bit losted :)
4736.25
script: /* Toggle view rotation style */ var newvrs, vrs = moi.view.rotationStyle; if ( vrs == 'World' ) newvrs = 'Free'; else if ( vrs == 'Free' ) newvrs = 'FirstPerson'; else newvrs = 'World'; moi.view.rotationStyle = newvrs; var sidepane = moi.ui.getUIPanel('moi://ui/SidePane.htm').document; if ( !sidepane.getElementById('viewrotationstyle') ) { sidepane.body.insertAdjacentHTML( 'beforeEnd', '<div id="viewrotationstyle" style="position:absolute; left:5px; bottom:5px;"></div>' ); } sidepane.getElementById('viewrotationstyle').innerText = newvrs;
Okay, hope this worked.
4736.26 In reply to 4736.24
Hi Frenchy,
"""""""""Can you resume that these new scripts can make?""""""""
One of the script "Toggles" the view mesh angle from a fine to coarse setting of 5, 10 and 25.. The other toggles the camera view/rotation type of free, around world Z axis and first person. The scripts are experimenting with "toggling" more than one value.. So repeated keypresses will cycle through a given value set. Lastly, they are putting the current value at the bottom of the sidepane as a readout, so you know the current setting.
Let me know if that doesnt make sense or is unclear somehow.
4736.27 In reply to 4736.26
Thx for the explanation!
I must test them :)
Show messages:  1  2-21  22-27
