Parts won't export
All  1-17  18-20
4701.18 In reply to 4701.17
I got a surface with 3200 x 1.2mm holes, export without any problem in under a minute... there's clearly something wrong here !
4701.19 In reply to 4701.18
Hi DesuDeus, is your one a solid with little tubes also joined to the holes or just an individual surface?
4701.20 In reply to 4701.19
Individual surface, that's why :)
There's the tubes also but not the backface !
But I'm pretty sure that I tried to export the whole solid and it worked but it was too high polycount so I decided to do it with surfaces.
At this time I was on an i7 920 @ 3.5ghz and with 6gb of memory. It's better to export a cube before with low angle settings like 20° then export the solid, so that your exporter is set to 20° and not 5° for example !
Show messages: All  1-17  18-20
