Interface Problem
4692.1
Hi Michael.
I've just bought MOI and I have a problem with the interface, I need your help for solving the problem please.
Could be that I need to install something more?
I have Windows 7 64 bits, i5 750 and 12 GB RAM.
A greeting and thanks.
Size: 479.2 KB, Downloaded: 71 times, Dimensions: 1680x1050px
4692.2
If you have IE9 installed, it may not work. Try uninstalling IE9 and going back to IE8. Or, download the V3 beta which doesn't use IE at all.
4692.3 In reply to 4692.2
Hi SteveMacc.
I have uninstalled IE9 and now it runs perfectly!
Thank you very much for your answer.
4692.4 In reply to 4692.1
Hi polan, yeah there is some problem with IE9 that causes that initial blank UI on certain machines.
Aside from going back to IE8 another way to solve it is to maximize the MoI window and leave it maximized when you close MoI down so that it starts up maximized initially. That seems to also cure the initial UI redraw problem.
4692.5 In reply to 4692.4
Hi Michael.
Thank you very much.
Annotated.
4692.6 In reply to 4692.5
Hi, there's also a script to prevent IE9 from reinstalling through automatic updates:
http://www.microsoft.com/download/en/details.aspx?id=179
I will try it later, I had the same problem with a laptop.
Marc
4692.7 In reply to 4692.6
Hi Marc.
I'm sure that I'm going to learn more things than Moi :D and probably my english would by better because I'm praticing in the forum ;)
Regards.
