New Mar-9-2007 beta available now
 1-3  4-23  24-26
469.4 In reply to 469.3
Thanks guys!
> Now go get some sleep ;)
It's hard, I keep on finding cool new ways to use the booleans. :)
There are quite a lot of possibilities now
Check this out:
Tube with lines below it. For auto-extrude sometimes there is more than one direction that a line can be extruded in if it is on a world axis direction. Positioning the line a little bit away from the second object will disambiguate the direction and make it go towards the other object:
Select the tube, do Boolean intersection, select the lines and you've got cross-sectional cut planes:
Do a difference instead of intersection and you get thick slices, each of which is a solid (the way this part works is so cool):
And here's an interesting twist on the thick slices - here I selected all the slices and chamfered them all in one go, then unioned those back into a solid (had to do it in a couple of batches, it got a bit confused when trying the whole thing at once), then sliced it the other direction:
Ok, now time to get some sleep... :)
469.5 In reply to 469.4
Wow I just download the 26 feb released yesterday - you're fast great job!
469.6
Excellent!. It's all so much easier now!
If only we could use MoI in the kitchen. Oh, the things I could do to my vegetables!
469.7
Very nice update Michael, as always. I guess V1.0 is coming really soon !!!
***There is a better way to do things... Just find your Moment of Inspiration***
Hehe new powerful function!
Speed of releasing betas is like Bip Bip and the wolf coyote :D
Update french version for perfectionnist!
Just one accent replaced :D
Unzip it and replace FrenchString in folder C:..\Program Files\MoI beta Mar-9-2007\ui
EDITED: 10 Mar 2007 by PILOU
469.9
Woaw ! Just terrific !
I've been playing with it for an hour now and it's sooo incredible. So easy to create complex objects. And FUN ! ;-))
A major update in my opinion.
469.10
great new beta. I like the new boolean possibilities.
As far as i can see there are no new text string to translate?
MfG
sk2k
469.11 In reply to 469.10
Nope, no text changes for this version.
Just a precision about all combinaisons between "2 solides" using the Boolean Intersection "merge" :)
EDITED: 11 Mar 2007 by PILOU
Little test of functions of Mr George B 1814-1875 :)
469.14 In reply to 469.13
Hi Pilou, looks like you are having fun with booleans!
One interesting thing is that history will work for the case of boolean intersection between auto-extruded curves, so if you turn on control points and edit the curves for your intersection case, you should see the object update.
This is because this particular case does not delete any input objects, it only creates new objects. Deletion of the input objects is what normally breaks history right now.
469.15 In reply to 469.14
Are you sure of that ? Can you give a little example with the process :)
I have missed something !
469.16 In reply to 469.15
Hi Pilou, here is an example.
2 Circles, 90 degrees from one another:
Select one of them, then run Boolean intersection, then select the other one and push Done to generate this result by auto-extrude:
Because the original curves are still around and have not been deleted, you can turn on control points for either one and edit it and the intersection will update:
Ah ! I have made that with a curve and a solid and not with 2 curves !
469.18 In reply to 469.17
Yes, the solid as an input doesn't work with history right now, because that original solid gets deleted.
But with 2 curves none of the inputs are deleted - this is the case that works with history right now.
469.19 In reply to 469.16
This is a very cool trick. I have so much to learn about nurbs...
469.20 In reply to 469.19
Hi Joe, that is not about mystery of NURBS, but rather about Michael's astonishing skills! -Petr
469.21
Some quick notes...
-Now, when comming boolean curves, it proved to be very useful that Invert command works from within other running command like Trim or Boolean.
-Updated/fixed "gizmo" for rotating background image looks good and works fine.
-Thanks for implementing a way to turn off points by pushing Esc key. Priceless!
Petr
Trivial question but...
As the first choice for a boolean Intersection seems give different results :)
why with a same "first start"
order for choice of the "second set" give a same result!
Star / Circle / Polygon = Star / Polygon / Circle : is that normal?
Anxious rationalist :D
EDITED: 12 Mar 2007 by PILOU
469.23 In reply to 469.22
For intersection, multiple objects within a single set are first unioned together into a single object, and then those 2 unioned results are then intersected with each other.
Does that explain what you are seeing there?
For intersecting 3 objects in that way you may want to do that with 2 separate runs of the boolean intersection command, or possibly use merge mode instead.
Show messages:  1-3  4-23  24-26
