New Mar-9-2007 beta available now
 1-19  20-26
469.20 In reply to 469.19
Hi Joe, that is not about mystery of NURBS, but rather about Michael's astonishing skills! -Petr
469.21
Some quick notes...
-Now, when comming boolean curves, it proved to be very useful that Invert command works from within other running command like Trim or Boolean.
-Updated/fixed "gizmo" for rotating background image looks good and works fine.
-Thanks for implementing a way to turn off points by pushing Esc key. Priceless!
Petr
Trivial question but...
As the first choice for a boolean Intersection seems give different results :)
why with a same "first start"
order for choice of the "second set" give a same result!
Star / Circle / Polygon = Star / Polygon / Circle : is that normal?
Anxious rationalist :D
EDITED: 12 Mar 2007 by PILOU
469.23 In reply to 469.22
For intersection, multiple objects within a single set are first unioned together into a single object, and then those 2 unioned results are then intersected with each other.
Does that explain what you are seeing there?
For intersecting 3 objects in that way you may want to do that with 2 separate runs of the boolean intersection command, or possibly use merge mode instead.
469.24 In reply to 469.23
Not posted the following so there
I have 3 objects, but in reality we can put any numbers of object for "the second set"!
So that I ask if the order of selection of objects has or has not importance for end intersection (first being selected) :)
469.25 In reply to 469.24
I don't think it should make any difference.
The thing that makes a difference is what set you put the "extra" object in.
For instance if the 2 sets are ( 1 2 ) isect ( 3 ) or ( 1 ) iset ( 2 3 ), that can make a difference.
469.26 In reply to 469.25
And even (1,2) isect (3)
(1,3) isect (2) that makes also difference :)
Funny thing that Boole games :)
Show messages:  1-19  20-26
