For intersection, multiple objects within a single set are first unioned together into a single object, and then those 2 unioned results are then intersected with each other.
Does that explain what you are seeing there?
For intersecting 3 objects in that way you may want to do that with 2 separate runs of the boolean intersection command, or possibly use merge mode instead.
