New Mar-9-2007 beta available now
 1-11  12-26
Just a precision about all combinaisons between "2 solides" using the Boolean Intersection "merge" :)
EDITED: 11 Mar 2007 by PILOU
Little test of functions of Mr George B 1814-1875 :)
469.14 In reply to 469.13
Hi Pilou, looks like you are having fun with booleans!
One interesting thing is that history will work for the case of boolean intersection between auto-extruded curves, so if you turn on control points and edit the curves for your intersection case, you should see the object update.
This is because this particular case does not delete any input objects, it only creates new objects. Deletion of the input objects is what normally breaks history right now.
469.15 In reply to 469.14
Are you sure of that ? Can you give a little example with the process :)
I have missed something !
469.16 In reply to 469.15
Hi Pilou, here is an example.
2 Circles, 90 degrees from one another:
Select one of them, then run Boolean intersection, then select the other one and push Done to generate this result by auto-extrude:
Because the original curves are still around and have not been deleted, you can turn on control points for either one and edit it and the intersection will update:
Ah ! I have made that with a curve and a solid and not with 2 curves !
469.18 In reply to 469.17
Yes, the solid as an input doesn't work with history right now, because that original solid gets deleted.
But with 2 curves none of the inputs are deleted - this is the case that works with history right now.
469.19 In reply to 469.16
This is a very cool trick. I have so much to learn about nurbs...
469.20 In reply to 469.19
Hi Joe, that is not about mystery of NURBS, but rather about Michael's astonishing skills! -Petr
469.21
Some quick notes...
-Now, when comming boolean curves, it proved to be very useful that Invert command works from within other running command like Trim or Boolean.
-Updated/fixed "gizmo" for rotating background image looks good and works fine.
-Thanks for implementing a way to turn off points by pushing Esc key. Priceless!
Petr
Trivial question but...
As the first choice for a boolean Intersection seems give different results :)
why with a same "first start"
order for choice of the "second set" give a same result!
Star / Circle / Polygon = Star / Polygon / Circle : is that normal?
Anxious rationalist :D
EDITED: 12 Mar 2007 by PILOU
469.23 In reply to 469.22
For intersection, multiple objects within a single set are first unioned together into a single object, and then those 2 unioned results are then intersected with each other.
Does that explain what you are seeing there?
For intersecting 3 objects in that way you may want to do that with 2 separate runs of the boolean intersection command, or possibly use merge mode instead.
469.24 In reply to 469.23
Not posted the following so there
I have 3 objects, but in reality we can put any numbers of object for "the second set"!
So that I ask if the order of selection of objects has or has not importance for end intersection (first being selected) :)
469.25 In reply to 469.24
I don't think it should make any difference.
The thing that makes a difference is what set you put the "extra" object in.
For instance if the 2 sets are ( 1 2 ) isect ( 3 ) or ( 1 ) iset ( 2 3 ), that can make a difference.
469.26 In reply to 469.25
And even (1,2) isect (3)
(1,3) isect (2) that makes also difference :)
Funny thing that Boole games :)
Show messages:  1-11  12-26
