Java error
All  1-9  10-14
468.10 In reply to 468.8
Is it possible to disable it temporarily and see if that is interfering?
468.11 In reply to 468.9
Ok, one other thing that might help narrow this down - when MoI is maximized, please hold down the Ctrl key and click on the little "MoI" title label that is in the upper-right corner of the screen, next to the minimize/maximize/close buttons.
That will bring up a debug menu - choose "Show Log", and in the log window, please select all the text, Ctrl+C and then Ctrl+V into a message here.
If something has failed to run as expected, it is possible that there may be some clues written to the log that may help with the diagnosis.
468.12 In reply to 468.11
this seems to have fixed it
"Here“s my first post!
I am using Windows XP with Internet Explorer 6.0.2800.1106 with SP1 and a few updates
(last was Q330994).
I fixed this issue by clicking on "Start Menu" - "Run", and entering the following
entries on command prompt:
regsvr32 msscript.ocx [enter]
regsvr32 dispex.dll [enter]
regsvr32 vbscript.dll [enter]
That worked fine for me...Bye!"
468.13 In reply to 468.12
Great! Thanks for reporting back here, that will help me next time someone runs into this.
That means that somehow your system registry got a bit garbled and was missing the information for the scripting engines.
468.14 In reply to 468.13
Thanks for everybodies help and suggestions.
Micheal
Program looks very good for a beta release. I always thought Rhino was great since it had followed the Autocad type workflow that I was used to. We tried a few things quickly at work in Moi3D and converted for use in Lightwave seem to work great. I really like the mesh density slider when saving (sim to rhino)
I know you will be bombarded with feature comments so i will hold off untill i test it a little more.
Show messages: All  1-9  10-14
