MMCX Connector Tut?
All  1-7  8-10
4636.8
Hello Michael,
Let me try to recreate it with one row. I'm flowing hundreds of objects, not one unified surface. I'll send over a smaller file, thanks.
4636.9
Hello,
Smaller number of objects works all the time, I'll send over a base file with one row of objects and you are then able to duplicate the objects to test out? I'd like to be able to use Flow since it does seem to be much faster and involves less steps. I am getting some weird Boolean errors as well using Twist, maybe the solid to be cut is too complex for the cutting object? I did find the simplest way to get a decent result that involves more than one cutting tool. When using this method I find that it really matters which cutting tool you use first. If you switch the procedure around I get all sorts of Boolean incompleteness which baffles me and probably includes some sort of math that is way above my head. Thanks.
4636.10 In reply to 4636.9
Hi OSTexo,
Yeah that should work.
> object?
It's probably something more like edges that go through the deformer engine are not getting a tight enough accuracy between their UV parameter space curves and their deformed 3D edge curves. If that's the case then I may need to change how edges are deformed.
I'll probably need some test cases in order to make changes like that, to make sure that I'm actually solving the problem and not actually making things worse instead.
Show messages: All  1-7  8-10
