MoI to Max
All  1-6  7-11
4627.7 In reply to 4627.6
When I have trouble with FBX and Max I have found exporting out as a SAT and importing the SAT into 123D then exporting that file out as a DWG. Max then has no problem with the DWG from 123D. It's a very high poly count but works well.
cheers
Val
4627.8 In reply to 4627.7
GOT IT! If you download Autodesks Connection Extension you can import SAT files and render NURBS directly. Smooth as a baby's ...
Size: 287.7 KB, Downloaded: 164 times, Dimensions: 1000x647px
4627.9 In reply to 4627.8
Nice tip and rendering. Its probably still performing tessellation though, you can check the quality by placing some white(no diffuse shading, just a constant colour) rectangular strips above the car - then zoom right in - especially where you have high curvature rounding.
4627.10
I find that FBX works fine with Max (although you need the latest version). Best results seem to be using N-Gons.
4627.11
I put a car paint shader on for this rendering just because I never used it before. Later I tried the Arch n Design materials and all the reflections got goofy. Also, when you import the scale gets goofed up. So it's by no means a hassle free process, but it's nice to see that the Max team is starting to consider solid formats more.
Show messages: All  1-6  7-11
