flow test beta3 newest version - surface tears
All  1-4  5-14
4625.5 In reply to 4625.4
That's great -
This morning I had another strange result with flow but didn't get a chance to save it.
I Twisted a box, then Flowed it along a curve. Very simple, right.
The result had some kind of exploded nastiness in the middle. Since I was flowing on a curve to curve basis, it didn't make sense.
Good luck!
4625.6 In reply to 4625.1
Hi jpaluck & Mike - these problems with Flow that popped up in the 2nd beta that you reported in this thread here should be fixed now in the new one, please let me know if you still see Flow misbehaving like that again. I think I've got it tuned up pretty well now though.
4625.7 In reply to 4625.6
Will do. :-)
4625.8
Twist Turbo
Size: 844.8 KB, Downloaded: 106 times, Dimensions: 1660x1112px
For sadic dentist :)
4625.10
Hi guys! I don't understand as you do a twist with such figures???!!! Explain please...
P.S. Gif tutorials please...
My love MoI!!!
4625.11 In reply to 4625.10
Riko, the above image is an object that was twisted using a "flow on revolved surface" technique.
See here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4549.1
The twisting in the wheel object above was done by using a flat revolved circle for the reference plane and a surface that was twisted as the target.
So the Flow command will match the two surfaces and you will get an object that matches the point structure of the target surface.
The twisting of the target surface was really a cone that was twisted and then flattened.
I hope this explanation helps, I'm not sure how to else describe it.
The turbine shape in the second image looks like a Twist command was used.
4625.12 In reply to 4625.10
Hi Riko - yeah like Mike mentions the first one is a little different using that technique with Flow that Mike cooked up.
The second one is kind of easier - that's using the new Twist command in the latest beta, you can get the latest beta here: http://moi3d.com/beta.htm and there's a new Twist command in there that you can find under Transform > Deform > Twist. You draw an axis for the twist and then enter in an angle for how much rotation you want at the top of the axis and it will twist your object around that axis line.
I'm still working (kind of bit slowly interspersed with some other work) on gathering some more descriptions of Twist.
4625.13
Thanks Magic and Michael!!!
My love MoI!!!
4625.14 In reply to 4625.3
Thanks for sharing that example Magic, really shows off the myriad possibilities of this new feature.
Show messages: All  1-4  5-14
