Screw Thread Tutorial Online
 1-6  7-26  27-46  47-51
4623.47 In reply to 4623.1
Ok a bit late but I wanted to ask this ,
What I don't understand, in the beginning of this tutorial, you tell us to make 20 copies of the 1 inch line.
After some more steps you delete all the copies and never use them. What is the meaning of those 20 copies? :-)
Peace,
Rich_Art. ;-)
4623.48
Hello Rich_Art,
It was an easy way to determine thread pitch. By using this method you have an easy way to get the pitch right on and will use that to determine the other parts of the geometry. You don't have to spend your time figuring out or inputting to many values, you just need to know how many threads per inch / mm you want to model. Hope that makes sense, I'm not so good at explaining things.
4623.49 In reply to 4623.48
Ah ok.. Thanks for the clarification...
Peace,
Rich_Art. ;-)
4623.50
Hello Rich_Art,
By the way if you are using metric sizes the pitch is easy to determine since the second number should be the pitch. If this is the case you don't need to go through that first process, just use that number to start your pitch triangle.
4623.51 In reply to 4623.50
Thank for the tip... :-) I hope I'll remember it when I'm making a new screw or bold.
Peace,
Rich_Art. ;-)
Show messages:  1-6  7-26  27-46  47-51
