Fullscreen in V3 (and pop under mouse menus ?)
All  1-12  13-15
4620.13 In reply to 4620.12
I certainly understand about the annoyances. The connector piece is one of them of course, but that is exactly what I would like to be able to control and modify.
I figured, if I can set and/or get the window panel coordinates via js then I should be to draw a custom connector anywhere along any of the borders as a separate entity on top. Kinda of a hack, but it may just work.
I plain webkit-enabled panel without any Moi-drawn borders/or edges at some point would be just great (i think that's what you mentioned before). Of course, it probably wouldn't be for everyone, which is why I would just make the default border style live in a CSS definition for all children to inherit from it...
Just wishful thinking at this point...
Luis
4620.14 In reply to 4620.13
Hi Luis,
I will probably end up with the colors defined in the CSS (or possibly in a separate color definition file that will contain all colors in it) - it's possible for custom C++ code to read some parameters out of the moi.css file itself, for some things that are drawn directly and not using the HTML engine.
It's actually doing that already in certain cases - including for the flyout border, the border comes from an image file that is defined as a flyoutBorderImage CSS property set on the body, that's how some flyouts have that darker style image on them, they are set to use the FlyoutBorder2.png image.
I do not think it will be feasible to make the borders drawn using the HTML engine though, I've tried to describe above the issues that make that difficult.
4620.15 In reply to 4620.14
Thanks Michael.
FYI, as long as the corner roundness and background colors are controllable then it doesn't matter to me which engine draws it. I would use whatever you can make available... :)
If you do plan on enabling something like that during the beta let me know so I can test it...opacity and padding would also be of interest...
Best,
Luis
Show messages: All  1-12  13-15
