Assign F1 and F2 to shortcuts ?
All  1  2-5
4619.2 In reply to 4619.1
Hi DesuDeus, what are you putting in for the Key part of the shortcut?
You should be able to just put in the text label F1 or F2 to use those.
Are they getting saved in the shortcut key editor (are they there when you close the dialog and open it again), but not activating when you push the keys or what?
4619.3 In reply to 4619.2
I relaunched MoI, the F1 help command is back. But now that I deleted it a second time, it works *huh*
4619.4 In reply to 4619.3
The F1 MoI Help keep coming back aha :(
4619.5 In reply to 4619.4
Hi DesuDeus - the F1 assignment will come back automatically at startup but it should only happen if F1 is not assigned to anything at all. That's how the default shortcuts get set up.
If you delete F1 and set your own custom F1 then it should not change.
Show messages: All  1  2-5
