Loop select edges ? Script ?
4615.1
I'm tired of manually selecting all those letters (got a lot) for a fillet :(
Is there a script that select all the edges on the same plane that are connected ?
See attachement :)
Size: 48 KB, Downloaded: 28 times, Dimensions: 1081x693px
4615.2 In reply to 4615.1
Hi DeusDeus
..by selecting an edge and using the left-to-right selection box, which will select only objects that are completely captured inside the box, you could get pretty fast in selecting those pesky edges.
Marco
EDITED: 17 Oct 2011 by MARCO
4615.3 In reply to 4615.2
Great ! I never tried to do it this way :)
That's saving me a ton of time, thank you !
Sometime the answer is so simple that I miss it aha
4615.4 In reply to 4615.1
DesuDeus,
Also try this script:
script:/*Loop selection*/moi.geometryDatabase.selectLoop();
Select at least two touching lines on the plane and it will find everything in a loop.
Works best if the lines you want are on a plane, otherwise, sometimes is goes into the wrong places.
4615.5 In reply to 4615.1
Hi DesuDeus, also some more information here on the select loop script method:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.22
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.32
