a variable radius or chamfer?
 1-3  4-23  24-31
4607.24 In reply to 4607.23
ah...
Thanks Michael.
Well, half the fun is figuring out how to tweak it! ;-)
But it sounds like you've put good thought into how to keep the UI stable and fast, as with sometimes V2 seems to forget to redraw things in the UI when the system is doing too much at once.
4607.25 In reply to 4607.16
magic
excellent, your lighting works well. very grateful.
regards
mario
Does the Viacad 2D/ 3D (100$) can import + export STL format?
(there is no complete lists' formats on the Internet page :(
http://www.punchcad.com/p-9-viacad-2d3d-v8.aspx
4607.27 In reply to 4607.26
Yes.
4607.28 In reply to 4607.27
Thx for the info!
PS So Viacad can import a polygonal file inside its system without problem?
I presume yes as I see Google Sketchup :)
4607.30 In reply to 4607.29
You can import a polygonal file into ViaCAD but it results in a mesh object - it's a separate category of object than a NURBS object and has somewhat different behavior, like for example you can't use a mesh object to do a boolean with I think.
4607.31
Tahks!
Show messages:  1-3  4-23  24-31
